Drain tube flaring tool
Forum for the exchange of boat building tools. Not a classified section, tools only please.
Re: Drain tube flaring tool
Post by cape man » Sat Dec 16, 2017 12:25 pm
Richard needs a flaring tool for the FS18. Who has the one that Cracker Larry started sending around years ago?
Dutch1
Post by Dutch1 » Sat Dec 16, 2017 1:08 pm
I have them.
Richard,
PM me and I'll send them to you.
Steve
Dutch1
Post by Dutch1 » Sat Dec 16, 2017 1:17 pm
I replied to quick before I realized who you were talking about. I PM'd him.
Steve
Larry B
Post by Larry B » Sat Dec 16, 2017 2:56 pm
Capeman, don't know what happened to Cracker Larry's, these are the ones I had and put them up for use.
I sent them to Dutch1
Completed: FL14, OD18
Post by cape man » Sat Dec 16, 2017 5:39 pm
Good on you! Might be worth a search for the Cracker's...
Post by cape man » Sat Dec 16, 2017 8:30 pm
Found the last posted location... Chopper Man!
Aripeka Angler
Post by Aripeka Angler » Sat Dec 16, 2017 8:40 pm
Hi Dutch,
I sent you a pm, thank you!
Larry and Craig, thanks. 8)
Richard
fishgitr
Post by fishgitr » Fri Dec 22, 2017 2:04 pm
Hi Dutch,
Could I possibly borrow this flare tool?
AA, We spoke before and you are going to do drains out of the sides of your sole.. Are you putting a brass drain tube there or just drilling the plywood?
Aripeka Angler
Post by Aripeka Angler » Fri Dec 22, 2017 5:51 pm
Hi Dutch,
Fishgtr,
I have drilled the drains through the sides of the hull. I have sized the holes for 1" id drain tubes. I beefed up the thickness of the hull where the hole is drilled so the plug doesn't protrude through the hull side when the drains are plugged. I am really happy with the setup. 8)
Dutch wants the flaring tool back after I finish using it tomorrow. If he is not quite ready for the tool, I'm sure he will let us know so I can send it to you first.
Richard
fishgitr
Post by fishgitr » Fri Dec 22, 2017 9:31 pm
Thanks AA..can you send post a picture on how you did that drain area? Thanks man!
