FS17 in Steinhatchee
Dutch1
Re: FS17 in Steinhatchee
Post by Dutch1 » Sun Feb 03, 2019 10:44 am
thb wrote:
Thu Jan 31, 2019 7:30 pm
Does anyone know how to take the curl out of the seastar hydraulic hoses? They were wrapped up in circles with tie wraps and seem to have taken a set. They seem to be a hard plastic material. I can stretch them out and then try a little heat from a heat gun.
If I was going to try I would put them in a big pot (washtub or something) of low rolling boiling water. This will soften the plastic up in a few minutes and it's a more uniform heat than trying with a heat gun. Keep the ends out. Or just dip the area you want to bend in the pot. When you think it's hot enough to bend without cracking see if it will stay without bending back into place. It's a gamble messing with old cables. I hope this helps.
cvincent
Post by cvincent » Sun Feb 03, 2019 8:03 pm
Try placing them in a black garbage bag and leaving out in the sun for 1/2 hour or so.
Completed D15, Building PH18
thb
Post by thb » Mon Feb 04, 2019 8:14 am
Hi all,
The hoses are actually baystar nylon hoses from what I have researched. They are brand new but were curled up inside the box by the factory. Nothing in the installation manual on how to deal with this. They say to support them every 2 ft. Good luck trying to do that inside a 2 inch conduit. The hot water trick I read about but have not tried yet. The hang them straight trick is kind of what I am doing. I have them tired off at each end of my 16 ft canoe. Installed brass lifting handles on each end of the canoe to tie them to. The black garbage bag trick should be worth trying. Having them stretched out on the canoe the curl is starting to come out. I will try heat gun again while they are stretched out. The heat gun seemed to help the other day when I had the cables wrapped around the fs17.
I got the first coat of paint on the inside surfaces of the boat yesterday. Have not painted the sides or gunnel supports yet. It is starting to look pretty good, IMHO.
I also got the fuel hose access panel installed with 5200 and two screws. Got it painted as well.
This is going to be a workboat ( 20 ft ) type of finish. Most of the horizontal surfaces including the deck will be coated with Kiwi grip. I love that stuff and how it feels on your knees and feet. The tan color interior is with interlux. It will take at least 2 coats maybe more. More painting today and then some light sanding of the first coat.
I also got the shop a little cleaned up and organized. Put together the bimini top but can't figure out where to mount it until interior is painted and kiwi gripped.
Some photos.
Regards
IMG_1332 (640x480).jpg (145.17 KiB) Viewed 171 times
IMG_1333 (640x480).jpg (134.57 KiB) Viewed 171 times
IMG_1336 (640x480).jpg (126.57 KiB) Viewed 171 times
IMG_1334 (640x480).jpg (186.85 KiB) Viewed 171 times
IMG_1335 (640x480).jpg (175.76 KiB) Viewed 171 times
Post by OrangeQuest » Mon Feb 04, 2019 8:54 am
Your boat is really coming together nicely!
Here is a very crazy idea: Run the hoses in a 2" pipe and either apply steam to one end with the pipe at an angle upward so the steam travels from one end to the other. with the ends hanging out so they don't get moisture in them. Even if the pipe is a lot shorter than the hoses you can slowly pull the hoses through so most of the hoses are exposed to the steam.
Told you it was crazy! :lol:
Post by pee wee » Mon Feb 11, 2019 8:53 am
I'd assume that putting it inside a conduit would qualify as continuous support, if you ran it in the open it would need support every 2 feet.
Post by Bogieman » Mon Feb 11, 2019 11:14 am
Wow! Very nice.
Users browsing this forum: Bellwether and 3 guests
