XF 20 Build
Re: XF 20 Build
Post by Jeff » Wed May 15, 2019 8:43 am
Nice progress CatfishHunter!!! Jeff
CatfishHunter
Re: XF 20 Build
Post by CatfishHunter » Wed May 15, 2019 12:11 pm
OrangeQuest wrote:
Tue May 14, 2019 8:02 pm
I like the way your live well turned out and the boat really is coming together. What size tank did you wind up getting in the area you wanted? Looks like it was make for the space!
I settled on a 12 gallon tank only because of space constraints. The larger ones were either to tall or to wide... During scallop season I can always tuck a small kicker can out of the way if i need too.
fallguy1000 wrote:
Wed May 15, 2019 12:12 am
I say drill her when you can!
Yes good idea, I'll take what i can get these days. :lol:
CatfishHunter
Re: XF 20 Build
Post by CatfishHunter » Sun May 19, 2019 2:06 pm
I cut a few holes in the boat, rear deck hatches are in place. :lol: Next I'm moving up to the front deck to finish the fish box section.
Re: XF 20 Build
Post by OrangeQuest » Sun May 19, 2019 2:41 pm
Man that is really looking good! With all that wood shiny like that you going to be doing some sanding to get anything to stick to it! Are you going to cover with cloth or straight to paint on the decks?
"that it isn't just an ordinary sort of boat. Sometimes it's a Boat, and sometimes it's more of an Accident. It all depends." "Depends on what?" "On whether I'm on the top of it or underneath it.
CatfishHunter
Re: XF 20 Build
Post by CatfishHunter » Sun May 19, 2019 4:05 pm
i resin coated the rear deck a while back to keep the weather off it because its been under the carport for so long. I'll sand it back and cover in cloth once i get everything below deck sorted out. The deck and hatches are on there for a temporary fit. i still have wiring and pumps to hook up before i glue any decks down.
garym
Re: XF 20 Build
Post by garym » Mon May 20, 2019 2:46 pm
My water tight hatches leak like a sieve. Make sure all your lockers have drainage. I didn't, huge mistake.
CatfishHunter
Re: XF 20 Build
Post by CatfishHunter » Mon May 20, 2019 3:23 pm
a beer can can pass through my scupper holes lol, Good looking out though. :lol: 8)
Re: XF 20 Build
Post by OrangeQuest » Mon May 20, 2019 6:47 pm
What are you saying? If you drop your beer it could get sucked out to sea? :lol: :lol:
Re: XF 20 Build
Post by Jaysen » Mon May 20, 2019 7:55 pm
If you drop your beer you get tossed out of any boat I’m on. So beer getting sucked out to sea could be an advantage.
CatfishHunter
Re: XF 20 Build
Post by CatfishHunter » Thu May 23, 2019 9:33 am
I just planned for a wet ride. all of my hatches and under deck storage have drainage to the main bilge(pump on each side of the tunnel). sole will be drained out each side at deck level. all of the under deck drain holes/scuppers are big enough for that empty beer can to pass through lol. You never know where those things might end up. 8)
