FS19 (-5%) in GA
Re: FS19 (-5%) in GA
Post by pee wee » Thu Jul 11, 2019 10:48 am
GuyP wrote:
Thu Jul 11, 2019 10:15 am
First filler coat on right side bottom panel. Used 6” plastic trowel at near 90 degrees. Used three batches of 3 pumps each. Look reasonable to you guys?
Yes, that looks very good. I like how you were careful and applied neatly (or at least cleaned up while wet). If you leave a lump, you have to sand the lump. If you own or can make wider spreaders for your subsequent coats, it'll be good.
Salty F17
Post by Salty F17 » Thu Jul 11, 2019 8:53 pm
Yep look right so far, fill the weave and ut will start to take shape ,take a look at my build you will see how it will start to look as u progress
Check out my build----C17---- hit the link viewtopic.php?f=2&t=63575
Post by Jeff » Fri Jul 12, 2019 7:57 am
Nice work GuyP!!! Jeff
Browndog
Post by Browndog » Fri Jul 12, 2019 1:52 pm
Looking good Guy!
GuyP
Post by GuyP » Fri Jul 12, 2019 2:15 pm
Thanks for y’all’s help and encouragement. Hope to have first coat completed later today or tomorrow.
GuyP
Post by GuyP » Tue Jul 30, 2019 9:34 pm
Quik Fair applications for filling obvious low areas at tape joints and weave filling is complete. Next steps 1) finish up this round of sanding, 2) additional fairing of rails and keel, 3) apply graphite powder quite coat and fill low spots, 4) prime with System 3 Yacht Primer.
My Question: if I decide to coat the bottom with epoxy/graphite, can I do that over the primer?
I intend at this point to use EMC Quantum Polyurethane on the entire hull but want to know my options.
Thanks
Salty F17
Post by Salty F17 » Wed Jul 31, 2019 6:41 am
Yes you can appy the graphite over the primer but i would use the s3 primer instead of the emc primer and use the emc paint on top of that
GuyP
Post by GuyP » Wed Jul 31, 2019 7:29 am
Thanks Salty. I was planning to use S3 primer on either and it’s good to get the confirmation that it works under EMC.
GuyP
2 part paint measuring question
Post by GuyP » Thu Aug 08, 2019 9:31 pm
Any tips on pouring out of cans of System 3 Yacht Primer? I’ll be using graduated mix cups and mixing maybe a pint at a time. What’s the best way of getting it out of the cans without making a mess?
joe2700
Re: 2 part paint measuring question
Post by joe2700 » Thu Aug 08, 2019 10:30 pm
Holes around the rim for paint to drain back in: Image
The first pour out of a full can always makes a mess but not too bad after that.
Users browsing this forum: No registered users and 68 guests
