Thru Hull Questions
TW28RJ
Re: Thru Hull Questions
Post by TW28RJ » Sun Feb 21, 2010 4:57 pm
Proprietary blend of polymers = long chain polymer "Comon guys"..and here is homework assignment, read up on crevis corrosion and ss, monel too. For the gentleman that can't tell the difference between 304 and 316.. You need help. And you imply to the people that dont know that there isn't a difference.
I can quote numerous books on corrosion in the marine environment, articles in Boat builder, people like Bruce Pfund, Steve D'Antonio, the list goes on. I don't post on here because I have nothing else to do. I only post when I feel I can help someone. I also post in the hope that someone will look outside of this forum to learn something. When I here someone talking about stainless steel through hulls i know that eventualy they will end up with crevis corrosion so I post - And a plastic through hull, they become brittle as time goes on.. for a small boat maybe it doesn't matter if you 75 miles offshore it might.
There are people out that here that have an open mind and want to hear different opinions. I find it a dis-service when the same frequent posters with half truths dominate the list and squash every bit of common sense they can find. I once posted a a formula for dertermining the ahead tourque on the rudder for the tw28...One of the frequent posters rediculed it, strangely enough when I looked at his posts I found the only thing he built was one of the rowboats.. Why the need to come off like an expert.
Ever wonder why you don't hear more from the builders of the bigger boats?
TomW
Post by TomW » Sun Feb 21, 2010 5:23 pm
TW28RJ wrote:Proprietary blend of polymers = long chain polymer "Comon guys"..
by jacquesmm » Thu Feb 18, 2010 12:13 pm
TomW wrote:
Marelon . . . It is the only fitting that I know of that is equal to bronze and is recommended for below the waterline and Marelon through hulls are also recommended for below the waterline use unlike some other plastic fittings.
I would go one step further and say that Marelon is superior to bronze.Jacques Mertens - Designer
Yep when he argues with the boats designer! :D
Seth also did not say he did not know the difference between 304 and 316 SS he said they noticed little difference in the use of the two, you need to read closer. A lot of this going around lately must be winter. :?
Shine let's whip the dead horse!!!!
C17ccx, Mirror Dinghy
majorgator
Post by majorgator » Sun Feb 21, 2010 5:49 pm
I never said that there wasn't a difference, or that one material is better than the other. For the record, I do believe that 316 is more corrosion resistant than 304. Of course, my last post was based on my experience (which is non-disputable) working with these metals on a nearly daily basis in highly corrosive environments.
So what you're saying is that SST in saltwater will react just like other metals? There is a potential for crevis corrosion on nearly every type of metal in a marine environment.
strangely enough when I looked at his posts...
That must have taken some time.
Well we can't use SST thru-hulls because we they will corrode. We can't use plastic ones because they'll get brittle and break. Joel knows of a yacht that sank due to a bronze thru-hull. Brass is out too. What now shall we use?
Hopefully, this is my last post on this thread
This time I mean it. I'm not intending to cause a stir, but rather post how I see it and how I've experienced it. If my experience was otherwise, I'd say so. If my experience was not sufficient enough to make a productive statement, then I wouldn't :!:
seth
Saved by the Blood of Jesus!
See my XF20 Build Thread
majorgator
Post by majorgator » Sun Feb 21, 2010 5:50 pm
Tom beat me too it...again :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
michaelwpayton
Post by michaelwpayton » Sun Feb 21, 2010 6:10 pm
TW28RJ wrote:... One of the frequent posters rediculed it, strangely enough when I looked at his posts I found the only thing he built was one of the rowboats..
TW... how large a boat do I need to complete before I'm allowed to post an opinion on this board, re things that may come up here that are not directly related to building any particular boat? I would appreciate any guidence you care to offer. Perhaps you could format your reply as follows:
If you have completed a small row boat, you may post opinions re _________________________________.
If you have completed a small power boat (tiller), you may post opinions re ______________________________.
If you have completed 16-20 foot power boat (center console) ....
I'll let you complete the above list.
"all things should be as simple as possible... but no simpler"
woodboat
Post by woodboat » Mon Feb 22, 2010 9:35 am
I need a thru hull and I am thinking about hollowing out a piece of wood to avoid all these corrosion issues. It should work well on my boat
TomW
Post by TomW » Mon Feb 22, 2010 11:28 am
:lol: :lol: :lol: :lol: :lol: :lol: Now that's a flat's boat! :lol:
TW28RJ
Post by TW28RJ » Mon Feb 22, 2010 3:58 pm
iIm thinking for you three guys it probably needs to be based on how many teeth you have.. more then two (in front) you can post, less forget it. Then again (for you three) we could base it on how many appliances you have out on the front porch! More than 5 you can post..
This is a forum about boat building not a cult, or then again is it??
michaelwpayton
Post by michaelwpayton » Mon Feb 22, 2010 4:13 pm
TW28RJ wrote:iIm thinking for you three guys it probably needs to be based on how many teeth you have.. more then two (in front) you can post, less forget it. Then again (for you three) we could base it on how many appliances you have out on the front porch! More than 5 you can post...
Very clever, well thought out, intelligent and informative post TW. How much time did you spend developing it? Will your next be to tell some of us that our mothers wear combat boots?
tech_support
Post by tech_support » Mon Feb 22, 2010 5:01 pm
Ever wonder why we dont specify electrical drawings (other than the super basics ) :D
What happens if I pour sea foam over my 304 stainless thru hull?
