Jack Plate Compatable?
LSUred
Post by LSUred » Fri Oct 28, 2011 12:59 pm
I know next to nothing about outboards. This is the motor I'm looking at, and I plan to mount it to a jackplate. Now I can't tell, but this lip on the mount looks like a clamp style mount to me. Will this work with a jackplate? I was under the impression that you need to just through-bolt the motor to the jack, so i don't know if this will even work.
Thanks, Baron
Mad Dog
Re: Jack Plate Compatable?
Post by Mad Dog » Fri Oct 28, 2011 1:07 pm
If the tilt bracket has holes for bolting the engine to the transom then it will bolt to a jackplate as well. All the engines I have seen have a lip that slips over the transom. Only the lower HP engines actually have clamps. I cannot tell from the pic if the bolt through holes are there. :doh:
MD :wink:
tech_support
Post by tech_support » Fri Oct 28, 2011 1:35 pm
You do not need them, you will mount the motor using the bolt holes.
I have the same motor and the clamp screws are actually in the way, I should have cut them off.
you can sort of see it here...
LSUred
Post by LSUred » Fri Oct 28, 2011 1:55 pm
Shine does it interfere with the performance of the jack? those bolts looks easy enough to remove, that lip looks forged though
tech_support
Post by tech_support » Fri Oct 28, 2011 2:10 pm
no, but I do not move mine up and down. With 4" of setback the bolt come about 1/2" from hitting the transom.
Daddy
Post by Daddy » Sat Oct 29, 2011 9:56 pm
Pretty sure that you can saw the clamps off, they perform no function if you have the bolt holes.
LSUred
Post by LSUred » Sun Oct 30, 2011 10:56 pm
Do you think that would affect the warranty?
Daddy
Post by Daddy » Mon Oct 31, 2011 8:54 am
Warranty covers mainly mechanical parts, no problem, or check with your dealer. leave enough to form a hook over the plate. I was going to cut mine off if they interfered with anything.
tech_support
Post by tech_support » Mon Oct 31, 2011 9:03 am
probably not, but it doesn't really matter what we think :) I would contact the dealer from whom you plan to purchase
Users browsing this forum: Google [Bot] and 1 guest
