glassing w/slury vs neat
levicitus
Post by levicitus » Sat Jan 28, 2012 1:17 pm
what is the benefit of glassing with epoxy-silicate vs neat?
sds
Re: glassing w/slury vs neat
Post by sds » Sat Jan 28, 2012 2:14 pm
What is epoxy-silicate and what benefits are you proposing?
dbcrx
Post by dbcrx » Sat Jan 28, 2012 2:58 pm
I assume you mean using silica thickened epoxy for the fiberglass? If so you don't want to be wetting out cloth with thickened epoxy - it will make it hard to wet out.
What you can do is put a coat or 2 of slightly thickened resin on after you've wet out the glass - either when it's still tacky or when fully cured and sanded. This would help fill the weave of the cloth.
You can also use thickened resin to coat the surface you're about to glass if the surface is a bit rough and has small holes/scratches etc. Then the thickened resin will fill the small defects rather than leave small air voids under the glass.
Dave
My photo gallery:
Photobucket
levicitus
Post by levicitus » Sat Jan 28, 2012 4:50 pm
thanks that makes sense
rjezuit
Post by rjezuit » Sun Jan 29, 2012 10:59 am
I wouldn't use fumed silica to thicken it. It would be hard to sand. Use wood flour. Rick
Daddy
Post by Daddy » Sun Jan 29, 2012 1:13 pm
Squegee the heck out of it if you are doing it that way or the cloth will "float". I would wait and add the thickened epoxy on top where it belongs.
