RB 14 with jet drive build.
coryd
Post by coryd » Wed Feb 01, 2012 11:57 am
Just started a build on an RB 14. Wanted to get some opinions on some of my mods. first as the title states it will be powered by a Yamaha 650 jetski engine and pump. The pump is its own unit and not part of the hull like alot of the others and it has reverse. I am changing the transom to angle forward about 5 deg and curving it to give it that authentic inboard runabout look. and finaly I want to build it as a center console so it will look like a mini Hinkley. The primary use for the boat is as an auxiliary to ge back and forth between my big boat on the dock and my small boat on a mooring line in the same harbor. I know that i will need to beef up the glass schedual a bit and I have already gone 1/8 thicker on the frames. Feel free to shoot some comments and sugestions. thanks.
Re: RB 14 with jet drive build.
Post by jacquesmm » Wed Feb 01, 2012 12:48 pm
The frames do not need any reinforcement but the bottom does.
You are going to "pull and push the boat with the bottom".
Put a doubler where the jet drive will go and double the glass in that area.
All that with a good safety margin, like 12" minimum all around the bolting plate.
coryd
Post by coryd » Wed Feb 01, 2012 12:58 pm
By doubler do mean laminating an extra layer of ply from the inside hull bottom and if so can that go between the stringers and frames or do I have to trim those down to fit over the extra ply?
Post by jacquesmm » Wed Feb 01, 2012 2:00 pm
An extra layer first them install notched stringers over it.
coryd
Post by coryd » Wed Feb 01, 2012 2:20 pm
Thanks I will amend my notes. I was also assuming that i would not be needing the transome thickness that is on the plans and have set it up for only a 1/2 inch thick transome. In cc configuration I will need to raise the deck to allow 8" to clear the pump housing, will this be enough to change over to self a bailing cockpit?
Post by jacquesmm » Wed Feb 01, 2012 2:36 pm
Correct for the transom.
Raising the whole deck will affect the stability of the boat.
We did build Phantom 16 with a jet and raised only the aft deck.
coryd
Post by coryd » Wed Feb 01, 2012 3:23 pm
My hope was that by puting all the mechanicals so low in the hull and omiting the topsides for the center console configuration that they would cancel that out.
Post by jacquesmm » Wed Feb 01, 2012 3:48 pm
It does, a little bit but you raise the sole, the seats, the weight of the crew and that's most of the weights in a small boat.
coryd
Post by coryd » Wed Feb 01, 2012 4:07 pm
sounds like I will be doing a tunnel over the housing then. thanks
coryd
Post by coryd » Mon Feb 06, 2012 3:05 am
Just got finished with a long weekend of building and managed get to an assembled hull. Doing a mock up out of luan really helped me figure out a lot of the little trouble spots before cutting the real wood. I took lots of pictures of each step and even a few very helpful tips that made the build go smoothly. I will post them with some commentary just as soon as I figure out how.
