Console mounting fs17
LSUred
Post by LSUred » Mon Nov 11, 2013 8:05 pm
I'm not planning on building my console with a base, and it will be permanent. So fillets and tape on the inside(double) and outide will be sufficient for a CC, right? Or do I need to build a lip on the inside to do a bolt through? The plans only show consoles with a base so I'm just curious :doh:
Steven
Re: Console mounting fs17
Post by Steven » Tue Nov 12, 2013 9:23 am
I taped mine down with 12oz. biax tape inside and out. IIRC I did two layers outside 1 layer inside. Don't want it going anywhere. ;)
Post by jacquesmm » Tue Nov 12, 2013 9:28 am
Steven
Post by Steven » Tue Nov 12, 2013 9:42 am
Jacques,
I think most of our consoles are do not have bases as in the diagrams. I assume tabbing it down with 12oz biax inside and out is just as good as that is how your diagram shows the bases attached.
Steven
Post by Cracker Larry » Tue Nov 12, 2013 10:31 am
Mine is attached just like the rest of the boat. Glued, filleted and taped. It's as strong as any other part of the boat.
LSUred
Post by LSUred » Tue Nov 12, 2013 2:39 pm
Thanks! I figured it would be fine, just wanted to check first
Post by jacquesmm » Tue Nov 12, 2013 3:00 pm
Yes that's fine.
It's true that our consoles do not have a lip. That lip is only necessary if you want a removable console that you bolt down.
Users browsing this forum: Sorin. and 5 guests
