Eric's C21
Fair WX Pilot
Re: Eric's C21
Post by Fair WX Pilot » Wed Nov 20, 2019 8:53 am
Nice idea with the foam, took ages to go around the double curvature parts in wood.
Alan.
Re: Eric's C21
Post by Jeff » Wed Nov 20, 2019 10:47 am
Nice use of the foam!!! Jeff
Re: Eric's C21
Post by Eric1 » Wed Nov 20, 2019 11:52 am
Thanks Guys! I'm glad I had it on hand, saved a bunch of work.
It only took a little more than an hour to sand this side level this morning.
I fitted the opposite side:
And Glued them in place.
This was about 4 oz. of glue.
glossieblack
Re: Eric's C21
Post by glossieblack » Thu Nov 21, 2019 11:09 am
Nice solution. :D
Currently building Jacques Mertens ST21 "Skinnydip". Boating adventures: Splash testing and using 'Skinnydip, as a basis of further building refinement; Adams 44’ sailing sloop "Great Sandy" (cruising and maintaining); Iain Oughtred Feather Pram "Mini Dip" (building); Jacques Mertens R13 "Wood Duck" (built and due for maintenance).
Re: Eric's C21
Post by Eric1 » Thu Nov 21, 2019 11:09 am
After sanding the left side cleats to level, I decided to use the dam technique to fill the void at the end of the short stringers and the bow.
I'm not sure how well the two part foam will fill tight corners so this is just a safety on my part.
I'm sure I'm doing unnecessary things as I build, but hey, it's my first build. :lol:
Here's the Dam Pictures:
As I checked level this morning I found the last piece on the right was low.
I made a dam at the bow and built up the top to raise it.
Current status:
If all of the glue sets I'll coat the foam with epoxy to seal the ten billion small pores.
Re: Eric's C21
Post by Eric1 » Thu Nov 21, 2019 11:13 am
Nice solution. :D
Thanks Glossie. I know it has saved me some time. I like working with foam.
If I ever finish this build I'd like to build a GF16 in all foam.
Dan_Smullen
Re: Eric's C21
Post by Dan_Smullen » Thu Nov 21, 2019 11:56 am
Hey, Eric. I have a Throwback Thursday question for you.
Do you recall how you manged tape around the overlap of the upper and lower side panel at the transom?
Did you level up the 1/4" step at the edge of the upper panel, stop tape at he step, or just tape right across the step?
Re: Eric's C21
Post by Eric1 » Thu Nov 21, 2019 2:27 pm
I sanded a tapered transition and put enough fillet to allow the tape to form.
Then after glassing the sides I came back and built the edge back up and sanded it to form.
You can see the transition if you look closely. I'm trying to find the pictures where I filled it and built it back up.
Re: Eric's C21
Post by Eric1 » Thu Nov 21, 2019 2:44 pm
Piece of 1/4" aluminum with peel ply tape to work surface.
Filled and covered with tape.
This worked ok but I still had to use quick fair and a block sander to get it right.
Dan_Smullen
Re: Eric's C21
Post by Dan_Smullen » Thu Nov 21, 2019 8:20 pm
Thanks, Eric. Sounds like you filled it in, then recreated the step feature. Is this right?
To avoid hi jacking your thread, I posted a new question.
Forgive me for the interruption. Given the similarities between your build and mine just beginning. I've been using this thread and your pics as reference a lot.
Back to you regularly scheduled progress...
Users browsing this forum: seaslug and 5 guests
