Eric's C21
Re: Eric's C21
Post by Jeff » Wed Oct 30, 2019 3:29 pm
Excellent work as always Eric!!! Jeff
Dan_Smullen
Re: Eric's C21
Post by Dan_Smullen » Thu Oct 31, 2019 6:10 pm
Hey, Eric. Are you inclined to build any camber into the deck so it drains to the side, or just make it level?
I’ve been wondering about what approach is best.
glossieblack
Re: Eric's C21
Post by glossieblack » Thu Oct 31, 2019 6:33 pm
Very nice work Eric. :D
Re: Eric's C21
Post by Eric1 » Thu Oct 31, 2019 8:01 pm
I'm going with level.
Thanks Glossie.
piperdown
Re: Eric's C21
Post by piperdown » Fri Nov 01, 2019 10:23 am
Just wondering couldn't you have kerfed the side cleats to make the bends? Then fill the kerfs with thickened epoxy and put in place?
Regardless, looking great Eric and am I thrilled to know you're moving forward on the boat!!
Eric (aka, piperdown)
Re: Eric's C21
Post by jacquesmm » Fri Nov 01, 2019 11:44 am
The decks have camber as designed but the sole is flat. I count on the boat to move enough to drain. That's the way it is in all production boats but some lifeboats and surf boats have camber in the sole. It's rare.
Re: Eric's C21
Post by Eric1 » Fri Nov 01, 2019 4:15 pm
Yes that could have been done and I considered it. I felt this was faster and equally as good a technique.
Thanks Piperdown. :D
cracked_ribs
Re: Eric's C21
Post by cracked_ribs » Sat Nov 02, 2019 12:45 am
I have also seen the reverse done: to put a very gentle lift in the corners of the sole where it meets the frames, just to prevent water from pooling in the corners. Whether it's worth doing or not I have no idea but it's an interesting concept but I think Jacques' point is well taken: the boat should ideally be either covered up on on the water and if it's either of those, the water should be leaving on its own.
I would not camber a deck in a boat with exposed frames, though: that's directing it to an area with built-in obstructions.
Re: Eric's C21
Post by Eric1 » Sat Nov 02, 2019 8:56 am
That is my plan for the exposed frame. An old boat of mine had that issue. Over time rot developed there. Polyester layup, not mine, factory build.
Dan_Smullen
Re: Eric's C21
Post by Dan_Smullen » Sun Nov 03, 2019 6:54 am
Great points, Eric and Cracked Ribs!
