Eric's C21
Re: Eric's C21
Post by Jeff » Thu Nov 14, 2019 11:55 am
Really well done Eric!!! 56 in the building is quite cold!!! Jeff
Dan_Smullen
Re: Eric's C21
Post by Dan_Smullen » Thu Nov 14, 2019 6:55 pm
Looks like a nice flat surface with lots of glue area for the sole to sit on. What's next for you? Chase tubes?
Re: Eric's C21
Post by Eric1 » Thu Nov 14, 2019 7:57 pm
Yes, I'm thinking chase tubes.
Re: Eric's C21
Post by cape man » Thu Nov 14, 2019 10:06 pm
Really impressed and so happy to see you building.
Re: Eric's C21
Post by Eric1 » Thu Nov 14, 2019 10:25 pm
Thanks Cape man.
glossieblack
Re: Eric's C21
Post by glossieblack » Fri Nov 15, 2019 7:41 am
Lovely, keep at it. :wink:
Re: Eric's C21
Post by Eric1 » Fri Nov 15, 2019 7:43 am
Thanks Mate! :D
Re: Eric's C21
Post by pee wee » Fri Nov 15, 2019 8:19 am
That's several hundred feet of cleats, isn't it? Very neat work, good thing you took pictures!
Re: Eric's C21
Post by Eric1 » Mon Nov 18, 2019 1:21 pm
Lord yes it is. Thanks Pee Wee.
I removed the dams this morning. It was a success, the tops are filled nice and level.
In order to strike a line forward of what I've done I had to modify the end of my level.
Small piece of G10 mounted to the underside of my level.
The single screw allows me to match the curvature of the hull well enough to get this done.
If you do this note: You need to drill your hole off center of the extruded aluminum.
The extrusion has a "T" shape in the center for strength.
The application:
The result:
I thought about the next step, after this, over the week end. I think I'm going to cut and fit a temporary floor next.
I haven't decided which way to finish the boat yet. This will allow me to play with ideas. That's all for now.
I hope everyone is having a good Monday. :)
Re: Eric's C21
Post by Fuzz » Mon Nov 18, 2019 1:48 pm
Neat and clean like always.
Putting the deck down will change things a bunch and let to see stuff a little different. Good move dropping it in there for planning.
