My cx 25
Re: My cx 25
Post by jacquesmm » Mon May 04, 2020 12:39 pm
Aluminum frame? Yes but its the job of your fabricator to make it sturdy enough and to recommend good anchoring points.
Stationary use will be fine but some CS25 owners have installed small towers.
The boat can take it.
dalnilo
Re: My cx 25
Post by dalnilo » Tue May 05, 2020 4:50 am
the sides of the ttop I would like to make them in foam is possible.
as for the cabin cover, can it be extended as in the photo? they can use it as a sunbath
muratugurlu
Re: My cx 25
Post by muratugurlu » Sun Jun 14, 2020 10:21 am
The weakest point is the welding zone when you use aluminium.
dalnilo
Re: My cx 25
Post by dalnilo » Thu Sep 17, 2020 12:38 pm
the works are continuing, I am using foam 15mm density 80 resin coated on top with 600g biaxial
underneath with 300g mat.
how does it look to you?
Re: My cx 25
Post by fallguy1000 » Thu Sep 17, 2020 5:11 pm
I think your first side laminate is too stiff to torture well.
Is that the goal? 200g no mat will torture easier...otherwise you may have trouble bending..
Re: My cx 25
Post by fallguy1000 » Thu Sep 17, 2020 5:13 pm
Also, at the intersections; you can make a 3mm relief cut with an electric planer and avoid a fairing headache on the exterior.
dalnilo
Re: My cx 25
Post by dalnilo » Sun Sep 20, 2020 6:20 am
thank you for the advice, fortunately I rounded and grouted everything well, then I laminated, and it came out well.
dalnilo
Re: My cx 25
Post by dalnilo » Sun Sep 20, 2020 6:27 am
Re: My cx 25
Post by Fuzz » Sun Sep 20, 2020 1:58 pm
Your foam/glass work sure looks nice. This is going to be a very nice boat :wink:
Re: My cx 25
Post by fallguy1000 » Sun Sep 20, 2020 3:21 pm
I always struggle closing the edges of the 12mm core.
