Narfi's FS17 - Build Thread
jtdums
Post by jtdums » Sun Feb 11, 2018 7:28 am
Nice clean lay up on the hull bottom. Well done!
Sanding is cathartic...
Post by Eric1 » Sun Feb 11, 2018 9:58 am
Good report all around! Good to see you back at the build. Best wishes to you and the family. :)
Post by narfi » Sun Feb 11, 2018 9:40 pm
Sanded it all down yesterday with 38grit and got the transom ready to glass.
When I glassed the bottom I wrapped it over the transom 4-5 inches, so sanded that transition smooth and layed a solid layer over the transom and forward on the bottom 24inches.
I had layed a 6ft straight edge across the back and found a fairly uniform 1/8" hook all the way across. The plans allow for up to 1/4" so I am not worried, but going forward with this peice 24" shares the love of the multi layers at the corner over a greater distance.
Landon played outside all day.
Momma is convinced she is good enough to work tomorow... im not so sure....
Bitcoin is @ 8400
Post by Jeff » Mon Feb 12, 2018 10:16 am
Narfi, looking really nice!! Jeff
Post by OrangeQuest » Mon Feb 12, 2018 10:35 am
Very nice! Did you put one of your helpers in charge of letting you know when the epoxy is hard? :D
Post by TomW1 » Mon Feb 12, 2018 1:47 pm
That is one fine looking boat Narfi.
Post by fallguy1000 » Tue Feb 13, 2018 11:49 pm
Aren't you going to fair it all out?
Post by narfi » Wed Feb 14, 2018 3:13 am
Yes. Why?
I've been thinking a bit about it. I struggled a lot with pinholes on the canoe....
I think after my initial sanding to knock the cotton thread lumps off the top I will brush or squeegee a coat of straight epoxy then while it is still green the first good layer of fairing material.
My thought is that the straight epoxy will work down into the gaps between strands better than the thickened fairing material and eliminate any of those hidden pinholes before I even start.
However before I do that, I need to attach my chines and strakes and rubrails, I don't want to bond them over fairing material.
Post by topwater » Wed Feb 14, 2018 7:44 am
First round just use a loose mix of blended fairing filler and press it it in with a plastic squeegee.
Just fill the weave . On the hull sides you will have to go with a thicker blend to get it to hang.
Post by terrulian » Wed Feb 14, 2018 8:48 am
I my hands, pinholes can appear in pure epoxy when applied on any surface using any applicator. I'm talented that way. :D
