Fiberglass upscale cx25
PNWcx25
Post by PNWcx25 » Thu Oct 05, 2017 2:20 pm
I'm at the point where I need to order fiberglass, since I've upscaled the boat 9% one side of the hull is 50". The plans Biaxial, fabric 50" wide am I correct to assume I need to upscale the width of the fabric to 60" also.
Re: Fiberglass upscale cx25
Post by Fuzz » Thu Oct 05, 2017 3:13 pm
I have never seen glass that wide but maybe it is made. Sounds like you will need to use more than one piece :doh:
Post by Jeff » Thu Oct 05, 2017 3:19 pm
Fuzz is exactly correct, you should just should stay with the specified cloth and cut it as I don't think there is a biax over 50" wide!! Jeff
Post by jacquesmm » Thu Oct 05, 2017 4:33 pm
Correct. Wider glass exist but it is very rare. Overlap the 50" strips, each overlap is a stiffener, stronger than a single wider layer.
PNWcx25
Post by PNWcx25 » Thu Oct 05, 2017 5:02 pm
Thank you all.
Should I start at the center of Hull extending the fabric 25" each side or off set the fabric 6" from center and work out from there.
Post by Fuzz » Thu Oct 05, 2017 5:54 pm
If it were me I would overlap the keel 6 inches each side. The keel and the chines are the two places that will take the most abuse so they need to be strong. Keel is the backbone of a boat and it is hard to have too strong of a backbone :D
peter-curacao
Post by peter-curacao » Thu Oct 05, 2017 6:27 pm
Yes like Fuzz said start at the keel and work your way down (or up depends how you look at it :P )
Don't forget tape first
Post by jacquesmm » Thu Oct 05, 2017 7:59 pm
Just repeating what he said, those overlaps are the fiberglass skeleton of the boat, very important.
Thank you Fuzz.
PNWcx25
Post by PNWcx25 » Thu Oct 05, 2017 10:14 pm
Got It thanks,
