FS14 Bayou boat
Re: FS14 Bayou boat
Post by topwater » Thu May 17, 2018 8:13 am
90 percent of my sole is foamed with no limber holes . Just make sure you build good sole to hull joints so
they don't leak.
Re: FS14 Bayou boat
Post by pee wee » Thu May 17, 2018 9:17 am
. . and if you do limber holes, that's a good occasion to overdrill/fill/drill, you don't want any spots with raw wood in the bilges. The holes may end up an eighth of an inch above the bottom due to the added resin mixture, but that's not a big deal.
Re: FS14 Bayou boat
Post by OrangeQuest » Thu May 17, 2018 6:23 pm
Thanks for the replies Topwater and Pee wee.
I think I have decided to go with foaming everything that doesn't have an opening till I use enough foam to keep her close to the surface.
Re: FS14 Bayou boat
Post by Eric1 » Fri May 18, 2018 8:12 am
I'm with you on this, seems like a smart plan to me. :)
Re: FS14 Bayou boat
Post by OrangeQuest » Sat Jul 21, 2018 8:58 pm
The bilge pump connector:
I read they come with long leads so you make the connection as far up and out of the bilge as possible. I understand it's to prevent any water getting to the connection. I am using gold plated connections and will waterproof them once they are plugged in but they will only be 3" above the bottom of the bilge. Is it acceptable?
Re: FS14 Bayou boat
Post by OrangeQuest » Tue Sep 18, 2018 7:00 am
Question!!
Water separator/fuel filter assembly, what to use? This one seems simple enough and is a quick change out of the whole assembly with the bracket bolted in place.
https://www.iboats.com/shop/racor-snapp ... in-2m.html
Price is not to bad and you can get it with 2 micron or 10 micron filters.
Thoughts please?
"that it isn't just an ordinary sort of boat. Sometimes it's a Boat, and sometimes it's more of an Accident. It all depends." "Depends on what?" "On whether I'm on the top of it or underneath it.
thb
Re: FS14 Bayou boat
Post by thb » Tue Sep 18, 2018 7:10 am
It looks pretty good to me and I love the fact that it has a clear plastic bowl so you can see when it has water in it and drain it on the spot. Don't know about the quick disconnect from its mount bracket. Cool idea.
Regards
Tom in Steinhatchee
Re: FS14 Bayou boat
Post by Capt UB » Tue Sep 18, 2018 9:09 am
Regards
Tom in Steinhatchee
I think you can only use the plastic above deck, but the metal ones anywhere.... ?
Re: FS14 Bayou boat
Post by Jaysen » Tue Sep 18, 2018 9:24 am
those plastic "see through" kind are common on big boats and are always below deck. i would think you'd want it where you can see it easily and with regularity. I've always seen them in the engine room first thing when you open the door/hatch (atomics do keep them further from the engine/ignition sources, but they are still in there).
And I do know there is difference between diesel and gasoline. hence my mention of my experiences with the atomics which are common gasoline motors for blow boats.
Re: FS14 Bayou boat
Post by TomW1 » Tue Sep 18, 2018 10:50 am
Racor makes a fine product and that filter will handle almost any motor that will go on any of Jacques designs. It is a new product from Racor and the first time I have seen it so see if you can find some talk about it on other forums or other places on the web.
Users browsing this forum: Sherman87 and 2 guests
