Has anyone used truck bed liner paint on the hull inside?
Post by Capt UB » Mon Apr 30, 2018 8:13 pm
I'm using something like Nautolex marine vinyl flooring on the tops of the decks and sole.
Re: Has anyone used truck bed liner paint on the hull inside?
Post by Jaysen » Mon Apr 30, 2018 8:14 pm
Someone in these forii used monstaliner. Does that count?
Class Mini 580 welcome post.
Post by Capt UB » Mon Apr 30, 2018 8:27 pm
Just left an email about using over epoxy. Lots of colors and the texture looks like it would hide a few mistakes...
Post by narfi » Tue May 01, 2018 1:24 am
The liners I've used are 2 part polyurethane, very similar chemical makeup to the high quality paints, it's just applied much thicker.
My guess is the only drawback would be weight and cost, with the benefit of ease and durability.
Post by Fuzz » Tue May 01, 2018 1:50 am
I have been thinking about what to use on the floor of my project also Narfi. I was going to use Kiwigrip and was going to pick it up while I was at west Marine today in Anchorage. Last time I was there they had lots of gray. This time they had everything but gray :cry: So now I might just go see the guy I know who does Rinio lining. I think that will be $800-1000 but I am not sure. Sounds high but I would need $300 in Kiwigrip so it is not all that much more.
Post by narfi » Tue May 01, 2018 1:57 am
Well kewigrip scares me with its sucptibility to fuel and chemicals.
Rhino liner isn't rocket science, just mix and spray with spackle gun or roll with textured roller.
glossieblack
Post by glossieblack » Tue May 01, 2018 3:30 am
Blueflood and Noles used monstaliner. Both loved it.
Post by Capt UB » Tue May 01, 2018 5:50 am
Monstaliner is 100% UV Permanent with 5 Year Guarantee not to chalk, fade or discolor. Once installed, Monstaliner requires little or no maintenance and continues looking great without any topcoats, sealants or protectants.
https://www.shop.monstaliner.com/1-Gall ... 55RK1G.htm
Post by Capt UB » Tue May 01, 2018 6:05 am
What surfaces will Monstaliner bond to?
Monstaliner will bond to most clean/dry surfaces, including painted or primed steel, wood and fiberglass. Prepping the surface is critical for best results. See the “Installation Guide” included with the kit.
Post by Capt UB » Tue May 01, 2018 6:21 am
Just read most of Blueflood's Harmony HMD19 build. I think this will work. A few others have used it too.
Finally I'm not thinking too far out of the box!!!
