Maintaining panel gap
rbecker08
Post by rbecker08 » Thu Nov 29, 2018 12:29 am
I am getting to post more them I should but was out in the shop and have another question. I read about using nails and such to maintain gaps in hull panels but was curious on how the fit should be. In the front the nails are under pretty intense pressure getting squeezed between the panels. Is that okay or should there be a loose fit? Just trying to figure out if I need to remove material or pitch the nail then tack with epoxy to hold. Thanks Rich
Reid
Re: Maintaining panel gap
Post by Reid » Thu Nov 29, 2018 8:48 am
Rich,
The main goal is to avoid any wood touching wood (these are called "hard spots"). You want to leave a gap between all panels (1/8" give or take) wide enough for the epoxy glue to get in and make a good bond. The nails provide a guide to keep a consistent gap but they are not necessary in every spot. When you get to the bow things tend to get a little tighter. You may need to shave some of the wood back or make some adjustments aft in order to release some pressure. The most important things are to maintain a square shape that is free of convex or concave areas on the hull panels and avoid any panels contacting each other leaving no room for the epoxy glue.
Good luck,
Reid
- Steven Wright
rbecker08
Post by rbecker08 » Thu Nov 29, 2018 10:17 am
Rich,
Good luck,
Reid
Okay I got it. So I have some tight spots like below....I'll plan on running a 1/8" router bit down the seam where ever the panels touch and just work my way forward. I can force them together but that blows the ply upward. So I need to remove material not force it. Thanks
You can see what I believe will be a hard spot in the picture above
Reid
Post by Reid » Thu Nov 29, 2018 11:10 am
Before you start taking out material, get all the panels stitched completely together first. Leave the zip ties really loose so you have plenty of wiggle room and then start to tighten them slowly, paying attention to what the rest of the boat does when you tighten certain sections. I would hate to see you take away material until you have had a chance to see it fully assembled.
Reid
- Steven Wright
rbecker08
Post by rbecker08 » Thu Nov 29, 2018 1:45 pm
Got it I'll try that tonight and post a picture....it feels like I need to remove but let's verify
Post by fallguy1000 » Thu Nov 29, 2018 2:01 pm
I would make sure you have an oscillating tool around. Makes trimming ply ez.
rbecker08
Post by rbecker08 » Thu Nov 29, 2018 2:14 pm
I dont have one and this sounds like more then enough reason to go add to the collection.....good tip
Lon
Post by Lon » Thu Nov 29, 2018 2:24 pm
I always strive for this result-a Cracker Larry photo: Image
Lon FL14, GV11
Montana
rbecker08
Post by rbecker08 » Thu Nov 29, 2018 11:43 pm
So made some progress will probably be redoing tonight but let me know your thoughts. So pulled everything pretty close but I feel like I will have to remove some material. First is the front coming together looks pretty goo but I noted I could see frame a sticking out, picture two. Looking underneath the panels are floating off frame a based on being pulled to meet the bow mold. If that is okay I can probably get everything tightened up but feels like I need to remove material and loosen things up
Post by OrangeQuest » Fri Nov 30, 2018 6:12 am
I bought mine from Harbor freight and got it for less than $20.00 for the variable speed. Then the single speed was put on a coupon a few weeks later "spend $50.00 and get it for free" so I now have 2. The blades and sanding attachments is where you can spend some money fast. Having two I keep them both very handy on the work bench. I just dropped another $50.00 on consumables.
It is one of those power tools that pop into your head after you have exhausted all ideas on how to get something cut or sanded and then you think of it. Then you go "SOB, I should of thought of it first!" :wink:
Users browsing this forum: bklake and 1 guest
