Panga 20 Build
Re: Panga 20 Build
Post by Jeff » Wed May 15, 2019 8:45 am
Nice work FluidDynamic!!! Jeff
GuyP
Re: Panga 20 Build
Post by GuyP » Sat May 18, 2019 10:26 pm
Looks like pine for spray rails. Are they one piece? How are they attached? Please excuse all the questions. I’ll be attaching rails to a FS 19 build in a couple weeks and also covering them with fiberglass.
Thanks
FluidDynamic
Re: Panga 20 Build
Post by FluidDynamic » Sun May 19, 2019 7:37 pm
Yes it SYP. It's two pieces. There screwed in at the moment. I'm about to filet the joints, take screws out, fill holes, and fiberglass over them. SYP would be too soft to just epoxy over.
GuyP
Re: Panga 20 Build
Post by GuyP » Sun May 19, 2019 11:29 pm
Thanks. I’ll do the same for mine.
FluidDynamic
Re: Panga 20 Build
Post by FluidDynamic » Mon May 20, 2019 10:30 pm
I put the filets on the spray rails today. I used a plastic cup to spread the filet on the top of the rail. On the bottom, I just used a popcycle stick.
Re: Panga 20 Build
Post by fallguy1000 » Tue May 21, 2019 12:11 am
Fillets look great.
I am sort of partial to a vee shaped rail. I sure hope these work well for you.
I am also used to them being partway up the hull sides.
Are they spec'd lower?
Re: Panga 20 Build
Post by Jeff » Tue May 21, 2019 9:38 am
Nice work!!! Jeff
FluidDynamic
Re: Panga 20 Build
Post by FluidDynamic » Tue May 21, 2019 1:19 pm
Thanks, I placed spray rails along the chine as the plan indicated. I'm not sure the reasoning behind it. I thought ight about putting one higher towards the back as well.
Re: Panga 20 Build
Post by fallguy1000 » Tue May 21, 2019 5:46 pm
Things look good. Spray rails can be added as needed later. Or you might see if anyone else had to...9
Re: Panga 20 Build
Post by Fuzz » Tue May 21, 2019 5:54 pm
Check out this http://gallery.bateau2.com/displayimage ... play_media
It looks like things work pretty darn well without them being higher up.
