Panga 20 Build
FluidDynamic
Re: Panga 20 Build
Post by FluidDynamic » Wed Jan 09, 2019 9:20 am
Wed H 61 L 35, Thur H 57 L32, FRI H 59 L 39 The garage is much warmer than the outside temps. Should be at least 70 in garage today.
Re: Panga 20 Build
Post by fallguy1000 » Wed Jan 09, 2019 9:50 am
Epoxies generally cure okay above 60F. Below 60F, I have had trouble.
FluidDynamic
Re: Panga 20 Build
Post by FluidDynamic » Wed Jan 09, 2019 10:57 am
My question is, if it dips below, does it stop curing. Will it start to cure again if it is 60 and above?
Re: Panga 20 Build
Post by Jeff » Wed Jan 09, 2019 10:58 am
No, it does not stop but the curing process will slow as temps get cooler!!! Jeff
FluidDynamic
Re: Panga 20 Build
Post by FluidDynamic » Wed Jan 09, 2019 11:17 am
Ill check it when I get home from work. I forgot this morning. Its probably cured by now. It was above 60 for most of the night last night and my garage was warmer. When I was looking at the curing chart, I thought it was hours not minutes.
Re: Panga 20 Build
Post by Jeff » Wed Jan 09, 2019 11:55 am
OK, let me know!! Jeff
FluidDynamic
Re: Panga 20 Build
Post by FluidDynamic » Wed Jan 09, 2019 9:41 pm
The epoxy cured. No problem.
I placed the transom a little earlier. I ran out of 2x4's so I had to temporarily brace the transom. I'll build something more substantial tomorrow. On my plywood cuts, does it matter if it's off a little. The transoms edges overlapped each other a little. I'm assuming this will be taken care of with either sanding or epoxy putty? I guess the stringers are next. I've been checking the cross dimensions and the dimensions between each frame. Everything is lining up. The stringers should go in no problem. The stringers will be cut with notches. I'll have to cut notches in the frames.
Re: Panga 20 Build
Post by Fuzz » Wed Jan 09, 2019 11:37 pm
Glad to hear the epoxy set up like it should for you :D About the transom, sand off the parts that stick out too far. If it is a little short remember "gaps are good" This style of building is pretty forgiving of small errors.
Re: Panga 20 Build
Post by Jeff » Thu Jan 10, 2019 7:38 am
Glad the epoxy cured for you!! Watch your temps, especially the overnight drops!! Jeff
Re: Panga 20 Build
Post by OrangeQuest » Thu Jan 10, 2019 8:13 am
Not only dropping temps but in high humidity the moisture will want to stick to everything. Increases risk of epoxy wanting to blush. I avoid epoxy work if temps will be in the low 60s in a 24 hour forecast.
Users browsing this forum: Cowbro, joe2700 and 1 guest
