FS19 (-5%) in GA
piperdown
Re: FS19 (-5%) in GA
Post by piperdown » Thu May 30, 2019 10:34 pm
GuyP wrote:
Thu May 30, 2019 10:06 pm
I should have mentioned that they’d be glassed. Thanks for tip. I will round before gluing down. Does placement as well as 8’ length look ok?
It does, although I think optimum is 10-12 inches from the transom for water flow.
Eric (aka, piperdown)
GuyP
Post by GuyP » Sat Jun 15, 2019 9:51 am
Type of cloth best for covering strakes and spray rails?
I glued pre-routed strakes in place using braces to ceiling joists. I then filleted joints and covered in 12 oz tape. I plan on gluing on spray rails using temporary screws.
What’s the best material for covering spray rails? I’ll need to fill a few soft spots on strakes where cloth is not solidly against the wood. On hand I have 6 inch wide 12 oz tape, 12 oz cloth and 4 inch 6 oz tape on hand. I don’t think the 4 inch tape will be wide enough for the rails.
Thanks for your advice in advance.
GuyP
Post by GuyP » Sat Jun 15, 2019 11:11 am
PS: I also have 6 oz 50 inch wide biaxial which I could cut strips.
Post by narfi » Sat Jun 15, 2019 12:36 pm
I wanted mine to be pretty abrasion resistant. So I overlapped two layers of 12oz tape 6" wide.
GuyP
Post by GuyP » Sat Jun 15, 2019 6:10 pm
Temporarily fit the spray rails. Will glue in place and fillet tomorrow.
Salty F17
Post by Salty F17 » Tue Jun 25, 2019 10:27 am
Looking good so for
GuyP
Post by GuyP » Tue Jun 25, 2019 12:32 pm
Thanks Salty. A general question for all: should I apply neat epoxy to the edges of taped and overlapped seams before beginning fairing with blended filler mix? Some edge fibers were loosened up with the initial sanding. Strakes and splash rails have been glassed. When I finish sanding I think I’m ready to start fairing. I’m finished with right half of bottom panels in this pick.
Post by pee wee » Wed Jun 26, 2019 10:55 am
It sounds like you could answer this question for yourself! If your first coat of fairing is a thin coat of epoxy/woodflour to fill the weave, then that should suffice to glue down those loose fibers in the same process.
GuyP
Post by GuyP » Wed Jun 26, 2019 3:18 pm
Was thinking that way just wanting confirmation. Hate to think about getting a later of something down and finding out later otherwise. I’ll be using BBC blended filler.
Thanks
Guy
GuyP
Post by GuyP » Wed Jun 26, 2019 3:20 pm
Was thinking that way just wanting confirmation. Hate to think about getting a layer of something down and finding out later otherwise. I’ll be using BBC blended filler.
Thanks
Guy
Users browsing this forum: Service Call and 2 guests
