Hull support after flip?
GuyP
Post by GuyP » Sun Aug 18, 2019 1:19 pm
I’ll be flipping my FS19 build in a few weeks. Many builders have flipped right onto a trailer. With molds removed and frames not yet in place will the hull bottom have enough support to hold it’s designed shape on trailer bunks while stringers, frames and bulkheads are secured? I saw somewhere that sheer shape may have to be adjusted with ratchet straps to secure shape prior to frame, gunnel, bulkhead installations.
Thanks
Re: Hull support after flip?
Post by narfi » Sun Aug 18, 2019 2:23 pm
I built my fs17 hull in my wife's dining ring room over the winter and flipped in the spring.
We lifted it up off the jig and went out the garden doors at an angle and up over the railing and onto the lawn. There we flipped it unsupported with no issues and moved it into the boat building tent.
I think if one person is trying to flip solo with straps it probably needs more support than if you have a half dozen guys doing it by hand. The straps concentrate the stresses where multiple people spread that load out and make it easier.
Post by fallguy1000 » Sun Aug 18, 2019 3:59 pm
You'll know when you walk in it if you think you bunked it well enough.
For my build, I made the entire think walkable. Different boat, but walkable was important.
jtdums
Post by jtdums » Mon Aug 19, 2019 8:16 am
I don't flip onto a trailer because I don't want the trailer to be in my way while doing interior. Also, the working height is determined by the trailer.
Instead, I like to make a very simple "cradle" out of plywood and pipe insulation that retains the hull shape for after the flip. This is attached to the original stongback after flip. The "cradle" is templated and cut before the flip while the hull is still attached to the station molds and upside down. On a small hull I usually do this at two points about equally spaced along the hull.
After the flip I ensure there is sufficient support along the length of the keel before doing any interior work and I keep my weight as centered as possible until the interior fiberglassing is completed.
I will try to find a picture.
Sanding is cathartic...
Post by fallguy1000 » Mon Aug 19, 2019 8:20 am
Nice to use a strongback.
Tapcon them to the floor with 2x cleats.
Once we flipped and reflipped the Skoota; we built a wooden cradle for it.
Now, we built a wooden trailer.
Chuck H
Post by Chuck H » Wed Aug 21, 2019 12:01 am
Guy,
I'm assuming the FS19 is a scaled up FS17. I don't think any normal trailer would support the unfinished hull very well. at least without elaborate modifications to the bunks. The variable deadrise (I think that's the right term), means there's no flat planes to lay flat on the bunks.
I built a cradle on the bottom of the hull before i flipped it and then bolted the cradle to the remains of my strongback.
seemed to work pretty good
Chuck
GuyP
Post by GuyP » Wed Aug 21, 2019 12:21 am
Chuck you are correct 19 is scaled up 14%. I will do something similar to your support method. Thanks
Browndog
Post by Browndog » Wed Aug 21, 2019 6:55 am
Congratulations Guy on being near the flipping stage. Well done.
Lots of different approaches to how to flip and what to do next. Do what works best in your situation.
The FS 19 I built went right on its trailer and everything worked fine.
Looking forward to what you do in the interior.
Salty F17
Post by Salty F17 » Wed Aug 21, 2019 7:43 am
I also just flipped i have a very good documentaion on the process (pics, and videos) check out my build maybe some help to u the link to my build is at the bottom .good luck with your flip
nathan
Post by nathan » Thu Aug 22, 2019 5:36 am
I supported my FS17 about the same as Chuck did his. Worked good. That was about 11 years ago
Oh I was up in your end of Lake Sinclair week before last cruising around breaking in a new Tohatsu 60hp.
