Free Canoe - Modified built
hawmjans
Post by hawmjans » Thu Sep 29, 2016 8:23 am
Hello all
As preparation for my first serious boat built (LB22 Nina is the plan) is am building a single seater double paddle canoe.
Used the free plans for the 14" Canoe from Bateau and modified the plans slightly.
Since I am rather heavy I increased the size and made the design front/back non-symmetrical, hoping to improve on load capacity and stability in the water. I will not be using the canoe in wild-water as well. Added some (floating) compartments.
Re: Free Canoe - Modified built
Post by Jeff » Thu Sep 29, 2016 8:40 am
hawmjans, nice clean work!! Looks good!! Jeff
hawmjans
Post by hawmjans » Thu Sep 29, 2016 8:46 am
More from the front:
hawmjans
Post by hawmjans » Fri Sep 30, 2016 3:45 am
Thanks for the complement Jeff !
I learned a lot already.
Had some serious problem completing the bow, which is still crooked and requires additional epoxy and grinding to correct. I choose to leave the bow section and last 300 mm of longitudinal fillets on assembly and since the cutting of the panels was not that "dimensional correct" (read just bad work) i had problems getting it somehow straight. But the wonders of epoxy filleting will compensate in the end.
hawmjans
Post by hawmjans » Fri Sep 30, 2016 3:51 am
And some more images from the outside hull
Thinking about the skeg
