Hand held drum sander?
Post by OrangeQuest » Thu Feb 08, 2018 8:20 am
Over the weekend I needed to sand the inside radius on my transom. I had nothing that would work even after going to HD looking at drum sanders stuff. No round sanding tools. So I took a hole saw and taped sand paper to it and did a fairly good job. This morning I looked on the web and found this.
2440
Seems easy enough to make a few in different sizes and maybe even put a handle on the end to get more pressure and better control.
What do you guys use?
Re: Hand held drum sander?
Post by pee wee » Thu Feb 08, 2018 9:25 am
I like these, but a bit pricey for infrequent use: http://www.leevalley.com/en/wood/page.a ... 00&p=45190
There's also an air powered version with a handle out the end that works really well, but it uses lots of air and costs a lot.
The nice thing about an inflatable drum is (counterintuitively) they sand with fewer dips and bumps than a hard drum.
Post by terrulian » Thu Feb 08, 2018 10:16 am
I could never find anything that worked as well as hand sanding and hand sanding and hand sanding.
Post by Jaysen » Thu Feb 08, 2018 12:13 pm
Well... if you have kids and are heartless, I’ve found “get that done before dinner if you want to eat” to be effective. At least it was for my dad when I was much much younger.
Class Mini 580 welcome post.
Post by pee wee » Thu Feb 08, 2018 1:25 pm
Yeah, when we were growing up that was considered building character. These days you risk a visit from DFACS.
Post by Capt UB » Thu Feb 08, 2018 3:09 pm
Making one for the tool box this weekend. Thanks.
Post by OrangeQuest » Fri Feb 09, 2018 6:06 am
I was thinking that I was pretty much done with inside radius sanding but my plans are to put a number of hatches in the deck and frames. There maybe more than I thought. Dremel makes a small drum sander that uses a rubber bushing that expands when you tighten a screw sown, maybe I can make some like that to use the replacement sanding tubes you can get for a table sander? If it works maybe a patent coming soon! :)
Post by terrulian » Fri Feb 09, 2018 9:49 am
Let us know. I tried a Dremel, which other builders have had success with, but in my hands it did more harm than good. :roll:
Post by pee wee » Fri Feb 09, 2018 12:37 pm
If the diameter isn't exactly a match it can cause problems- it's hard to do a smooth job when the drum is too small, and too large obviously doesn't work well. The nice thing about the flexible drums- and inflatable is more flexible- is it will smush in there to match what you've got. Smush is a technical term, btw, meaning "shape shift".
Post by OrangeQuest » Fri Feb 09, 2018 1:11 pm
Pee wee I understand what you are saying about the size match the size of the curve.
After getting to work and toying with a few ideas, I think the best would be to cut stacks of disks with a circle cutting, glued together. Drill the bolt that holds one end of the sand paper and go to town. Wouldn't take to many pieces of 1/2" plywood and regular wood glue to hold them together. Make a few different sizes and use sheet sand paper.
For a handle on the end I was thinking inline skate wheels. Very good bearings and just need to jam nut it to the end. I will make one over the next few weeks and post pictures.
