Homemade wooden pushpits?
Re: Homemade wooden pushpits?
Post by Bogieman » Mon Feb 11, 2019 2:50 pm
Capt UB wrote:
Mon Feb 11, 2019 2:29 pm
This page could give you some ideas on shape and size if you make them...
https://shop.hunterowners.com//hp/searc ... n%2520rail
Thanks CaptUB. I will take a look. It's supposed to rain a lot over the next couple weeks so it might be a good indoor project I might put one together and run some tests on it myself. It would cost almost nothing to build.
Post by Bogieman » Mon Feb 11, 2019 3:09 pm
Capt UB wrote:
Mon Feb 11, 2019 2:38 pm
Sorry you got me thinking....
How about flush deck rod holders as the base, then the right type of dowel (wood) would fit inside the holder... 1.50" dia. I think. Then build on to that...
:D
Post by Bogieman » Tue Feb 12, 2019 4:42 pm
Here are a few pics of my homemade pushpits, or one of them anyway. The plan is to roll each of the dowels in glass and then glue it together with thickened epoxy and FG tape. I wrapped masking tape to the ends of the dowels so they'd fit snug in the holes. The top L shaped piece is also temp taped in place.
The finished product would look much nicer than this. Still not sure if I'm going this way or with the SS.
Thank you Jaysen for your ideas.
Post by OrangeQuest » Tue Feb 12, 2019 4:45 pm
I don't see any pictures :(
I did do a search for what pushpits were and only came up with a young lady sitting on a seat in the corner of a sailboat wearing a bikini, her pushpits did look home made! 8O
Never mind, they loaded when I posted my comment
Post by OrangeQuest » Tue Feb 12, 2019 4:49 pm
I like the height and the shape of them, is the top "l" shaped pieces going to be wood similar to the base?
Post by Bogieman » Tue Feb 12, 2019 5:26 pm
Thanks OQ! The top part is also made of 1" wooden dowels in a L shape. The tops of the vertical pieces will be cut with a hole saw so it leaves a concave area for the dowel to sit. The whole assembly would be glassed and glued.
Post by Jaysen » Tue Feb 12, 2019 6:27 pm
I’m still thinking there needs to be a cross piece to support the middle of the angled dowels. Maybe 1/2” diameter. The concern would be a hit to that angled part. Even with glass it will be an area prone to damage.
What’s the cut schedule?
Post by Capt UB » Tue Feb 12, 2019 6:36 pm
The loading is the key, how much pull/pressure is going to be called on? A body falling overboard, a dingy (not smart in open waters) or kids in tubes?
FS14 SandPiper Launched 2018
LM18 LS RC Building
Never trust advice from someone who does not have a few bags of wood flour around the shop!
There are times that a belt sander with 32 grit can be like an artist brush.
Post by Jaysen » Tue Feb 12, 2019 6:53 pm
Basic safety lines. Figure 200-400lb (distributed 2 ends so half at each end) as a point load. If I did the math right, physics would say you’re talking about 800lb shock load.
Most of that would be distributed by the glass across the whole frame. I’m not convinced about the glassing Boogie and I have discussed. Current plan is 2 layer 12oz biax. I think it will need another 2 layers in the joints. And I’m thinking another “inner ring” to further distribute the shock load across more of the structure.
But I may be enjoying the thinking a bit too much.
piperdown
Post by piperdown » Tue Feb 12, 2019 7:44 pm
Can't speak to boats but for fall protection the anchoring point must be rated to 5000lbs tensile load for a non-certified anchor or a certified anchor done by an engineer for calculated loads.
I'd ask JM.
Eric (aka, piperdown)
