SB18 (help reading plans)
Piscisalfanet
Post by Piscisalfanet » Sun Nov 15, 2015 7:21 pm
Hello, I received the plans for the sport boat 18. and am in the process of translation to Spanish. I am not expert in English, I ask you that clarify me some terms and abbreviations that I do not understand.
What means this?
w.
fr.D
Re-drill
req'd.
Thanks.
Woods Designs
Re: SB18 (help reading plans)
Post by Woods Designs » Mon Nov 16, 2015 3:11 am
I can help a little
req"d is required, or necessary
re-drill means drill a hole again (presumably you make a hole, fill it with epoxy and the drill it out again to seal the edges)
FrD probably means forward
Richard Woods
Post by jacquesmm » Mon Nov 16, 2015 11:01 am
Richard is correct but for the other words, tell me on which drawing you see them: drawing number.
F is probably part of Fwd which means forward.
W part of WL = water line.
Piscisalfanet
Post by Piscisalfanet » Mon Nov 16, 2015 2:21 pm
I can now understand the term "Re-drill" and "reqd." but still I do not understand the terms "w." and "fr.D"
I quote the text of the plane # B281 / 3
High load blocks
Thru bolt to inside of trunk
3/8 "[10mm] to ply glass hull, trunk, fr.D. w. 2 biaxial layers.
"w." it could mean "with"?
"fr.D." -- :?:
thanks so much to Woods Desings and jacquesmm
Post by jacquesmm » Mon Nov 16, 2015 3:12 pm
Piscisalfanet wrote:I can now understand the term "Re-drill" and "reqd." but still I do not understand the terms "w." and "fr.D"
High load blocks
"fr.D." -- :?:
I agree that it is a little bit hermetic :)
Fr. D means frame D
fr.D w. 2 layers biaxial
means Frame D with 2 layers of biaxial.
That part of the drawing shows how the CB trunk is epoxy-fiberglassed to the hull and to frame D.
There is a piece of wood in front of the trunk, between the trunk and frame D, see the arrow.
That part is made from 10 mm ply, glassed to hull and frame D with 2 layers etc.
Piscisalfanet
Post by Piscisalfanet » Mon Nov 16, 2015 5:51 pm
High load blocks
"fr.D." -- :?:
Fr. D means frame D
Ok thank you very much.
