AR15 Tack Welding
emmalroc
AR15 Tack Welding
Post by emmalroc » Tue Sep 13, 2016 4:24 pm
Hi! I am currently making good progress on cutting out all of my pieces- right not I'm working on the frames. Do you recommend tack welding after the hull is stitched together, then taking all of the stitching out, then filleting and then fiber glassing? Also, for the stitching, do you recommend zip ties or wire? Thanks!
Emma
Re: AR15 Tack Welding
Post by jacquesmm » Tue Sep 13, 2016 4:48 pm
emmalroc wrote:Hi! I am currently making good progress on cutting out all of my pieces- right not I'm working on the frames. Do you recommend tack welding after the hull is stitched together, then taking all of the stitching out, then filleting and then fiber glassing? Also, for the stitching, do you recommend zip ties or wire? Thanks!
Emma
Look at our tutorials and you will see the sequence and the materials:
http://bateau2.com/howto/boat_in_box/index.php
(don't use as many stitches as on that boat, that guy exagerated, one every foot is enough).
Sequence: stitch, spot weld, remove stitches, build the seams.
Use plastic ties.
