SB18 keel AGAIN!!!
jasongavin
SB18 keel AGAIN!!!
Post by jasongavin » Tue Nov 08, 2016 10:25 am
Hi Guys
I am busy getting materials together to start building and was wondering if anyone has used a different timber species for the keel? For some reason my suppliers in this area (South coast UK) are questioning the suitability of the timber. I have told them in diplomatic terms that they are not yacht designers and should just quote me for what I have asked. My thinking is to go for oak which I know is about 40% heavier but should be strong enough.
Any thoughts would be appreciated.
Cheers
Jay
Re: SB18 keel AGAIN!!!
Post by jacquesmm » Tue Nov 08, 2016 10:32 am
You can go for oak but it is unnecessarily heavy.
I designed the boat but Evan Gatehouse did the keel engineering. Evan worked for Bruce Farr, designed America's Cup boats, he is a mechanical engineer and just finished sailing around the world. I think we can trust his keel specs.
Your advisers probably do not know about all the fiberglass layers that strengthen that keel.
If you want, you can add a couple of uni carbon layers and use the best resin, Silver Tip.
Evan_Gatehouse
Post by Evan_Gatehouse » Sat Nov 12, 2016 12:25 pm
Hi,
What sort of wood do they suggest? Some wood species have the same name but are different wood in different countries I.e. mahogany.
White oak has a reputation for not bonding with epoxy well. But aggressively sand the bonding surface, wipe down with acetone to remove oils and you should be O.k.
designer: FB11/GV series/ HMD18/
SK17,21/MT24
jasongavin
Post by jasongavin » Sun Nov 13, 2016 5:56 pm
Hi Jacques and Evan thanks for the info. I agree on the oak being too heavy and have now found a supplier to get me DF so will go down that route. Time to order and start building!!! :D cheers
Jay
emosewa
Post by emosewa » Fri Apr 28, 2017 3:06 pm
I believe our 1959 mahogany Thompson wooden strake 15' runabout also has a Mahogany keel.
you might try looking into cypress. It is probably much more affordable.
