AR15 deck and rigging???
Re: AR15 deck and rigging???
Post by jacquesmm » Fri May 24, 2019 10:02 am
Use something ;like a shock cord to keep that pull back line tight. If you don't the line will jump out of the groove.
You can also pull out and retract by hand. It's simple, no snag risk.
Post by terrulian » Fri May 24, 2019 10:13 am
Is that your lathe setup?
Biney777
Post by Biney777 » Fri May 24, 2019 11:31 am
This is the lathe set up, I also ran the bowsprit thru 2 2x4's to make sure there was no risk if it going out of control (completely). I used this just to smooth it out enough for the fiberglass sock to slide over it.
Lathe set up. I was going use both sides to secure it. But the one side was enough for the 15 minutes I used it.
Post by Capt UB » Fri May 24, 2019 12:24 pm
terrulian wrote:
Thu Apr 11, 2019 12:27 pm
Only 2? You guys aren't trying.
I miss those days.... We once put the bow under water, the poor foredeck guy had to cut the sail!! BOOOMM... Not my boat or spinnaker.
Post by terrulian » Fri May 24, 2019 12:25 pm
We need a "thumbs up" emoji here. :wink:
Post by Capt UB » Fri May 24, 2019 12:29 pm
Post by terrulian » Fri May 24, 2019 12:35 pm
Yep, that'll do.
Post by Jaysen » Fri May 24, 2019 12:56 pm
4 this week. 3 groundings. 2 rescues. Chutes in 20+. We had ours blow out on dousing due to a spare halyard being jammed at the masthead. Luckily I’m still fat and managed to put some weight on it (once we got one sheet back on board). I was really glad I wore my brown pants.
Better?
Post by terrulian » Fri May 24, 2019 1:22 pm
Sounds good, young fella.
Post by Jaysen » Fri May 24, 2019 1:43 pm
Thank you sir. I now have a healthy fear of
1. loose spin sheets
2. gybes
3. bosun's chair
