Fairing thickness?
asweany
Fairing thickness?
Post by asweany » Fri Nov 09, 2007 3:31 pm
I have discovered an area on my OD18 hull that may need about 3/16th of an inch of fairing compound. Is there a point where you can get the fairing too thick? Note to first time builders: Drink the adult beverages after you stitch and tab your hull. Thanks, Asweany
Post by tech_support » Fri Nov 09, 2007 4:49 pm
Where is the spot? If its an are that is subject to impact or wear and tear (keel, chine, etc), I would fill first with something a little harder like wood flour and epoxy. Then use fairing compound over.
3/16" is really not very much :wink: There are "yachts" with 1/2" or more of fairing compound on them
asweany
Post by asweany » Fri Nov 09, 2007 4:54 pm
It is in the area where the lower panel meets the chine panel about 12 inches back from the bow. I will use your suggestion and fill part with wood flour and then fairing compound. Thank you.
Spokaloo
Post by Spokaloo » Sat Nov 10, 2007 12:18 am
I have two spots where there is almost 3/8" of filler.....
E
Deedaddy
Post by Deedaddy » Sat Nov 10, 2007 9:23 am
My CX 25 has areas that took over 1/2" to change flats to curved.
