System Three Primer is great BELOW the waterline.
Post by jacquesmm » Wed Mar 18, 2015 11:35 am
I don't know where that rumor started but some say that the System Three Primer can't be used below the waterline.
This is not true. It clearly says in the primer literature that it is formulated to be used above and below the waterline. It clearly states that it is a perfect primer for bottom paint, below the waterline.
It is IMHO, the best general purpose epoxy primer available.
Use it in confidence below the waterline.
The System Three Yacht Primer is formulated to be used below the waterline.
THE WALRUS
Re: System Three Primer is great BELOW the waterline.
Post by THE WALRUS » Tue Jun 27, 2017 10:47 am
What would be a good bottom paint for a 16' power boat that has been primed with System Three Primer. The boat will be trailered so it will not be in the saltwater for long periods of time. Also does the primer have a shelf life. My primer is 3 years old but has never been opened.
Terry
bateau-webmaster
Post by bateau-webmaster » Tue Jun 27, 2017 11:02 am
We've got a number of great paint systems you could use. Most of the guys favor Awlgrip. It is a two part system, and can be rolled or sprayed. For ease of application, you might be etter served with a 1 part LPU paint, like Interlux Brightside, or Pettit EZ-Poxy. You don't need a true bottom paint, if your boat is going to be trailered. Most "Bottom Paint" Systems are for boats that live in the water, and are moored for long periods of time, they contain copper, and/or other biocides that inhibit growth of barnacles etc. (and aren't necessarily great for the environment, and the boat)
THE WALRUS
Post by THE WALRUS » Tue Jun 27, 2017 11:43 am
Thanks for the very quick reply to my question. Is System Three Primer that is 3 years old but in unopened cans still good to use. Thanks again for your help.
Terry
Post by Jaysen » Tue Jun 27, 2017 11:56 am
I"ll swear by the EMC stuff... Pricey but even and idiot like me got a good finish out of it. And it seems to take a beating pretty well.
Class Mini 580 welcome post.
bateau-webmaster
Post by bateau-webmaster » Tue Jun 27, 2017 12:21 pm
Terry
It should be, it's epoxy based. I would make sure when you open it, to stir really well, and make sure a mix stick hits the bottom of the can when you stir (if there's gooped up solids at the bottom, you might have to do a little extra stirring)
tcason
Post by tcason » Thu Jun 29, 2017 1:38 pm
Consider graphite finish on the bottom.
