Using a electric HVLP sprayer for SilverTip Yacht Primer (high build)
Post by Capt UB » Tue Oct 31, 2017 2:48 pm
I do not want to setup a Air Compressor and related equipment! Question 1: Do you OWN or have you used a ELECTRIC HVLP SPARYER?
Question 2: Will a electric HVLP sprayer spary SilverTip Yacht Primer (high build)?
I do not want to setup a Air Compressor and related equipment! I don't have the space or the need.
Thanks, Bob.
Home built boats, get their personality from the builder... My boat is NUTS!!! FS14, getting wet soon.... Next build; LM18 (Laguna Madre Skiff 18). This is a beautiful designed boat.
Re: Using a electric HVLP sprayer for SilverTip Yacht Primer (high build)
Post by pee wee » Tue Oct 31, 2017 3:13 pm
Thanks, Bob.
1. I do own an HVLP sprayer, and it should do a fine job of spraying that primer, but it isn't needed- just use a roller and you'll get good results.
Post by Capt UB » Tue Oct 31, 2017 3:27 pm
Thanks, Bob.
I was thinking of using it for the top coat too. I was told spraying gives a much better finish. I am spending the time to fair the hull.
Post by Jeff » Tue Oct 31, 2017 3:51 pm
Agree with Pee Wee, Roll & Tip it, that will get you very good results with a lot less work with sprayers!! I am sure you can spray the yacht primer but I don't know anyone that has done it!! Jeff
Post by Jaysen » Tue Oct 31, 2017 3:56 pm
Didn't Eric1 or Narfi spray S3 primer and it was ... not a good idea? Must have been Narfi, since I recall it being a smaller boat. and it was right side up.
Post by cape man » Tue Oct 31, 2017 4:05 pm
Roll and tip the primer for sure, in fact you may not even have to tip it. The S3 is pretty thick to spray unless you thin it, which to me counters the whole concept of a high build primer? You are going to sand it before the top coat anyway...
Spraying the top coat is a whole 'nother conversation and will be best answered when you have decided on a product. Lots of fabulous finishes here (not mine :help: ) so keep asking the questions.
Post by narfi » Tue Oct 31, 2017 4:50 pm
I just had a learning curve.... I plan to spray it again on my fs17.
Post by Capt UB » Tue Oct 31, 2017 5:11 pm
Rolling rolling Rawhide!
You guys are no fun.... I wanted to buy a new useless tool to play with!!
I'm going to roll it. Ya, don't plan on tipping it.
Ordering from BBC tonight!
Realy liking System 3 products...
peter-curacao
Post by peter-curacao » Tue Oct 31, 2017 6:37 pm
On my CS I sprayed everything, Highbuild, Primer and Finish, used different guns with different nozzles, but all with compressed air (small compressor)
Edit off course not the anti fauling.
