Resin percentage vac bag
Re: Resin percentage vac bag
Post by narfi » Tue Nov 14, 2017 2:46 pm
Hehe.... you might be more accurate.
Back on topic though and to the point,
5.2 glass
2.6 resin
It doesn't matter if you call it 50% resin to glass, or 33% resin to total, it means the same thing.
Even more important though, it is a good ratio for vacuum bagging, and if you have consistent results with this ratio without voids then you are doing good and probably no need to change anything.
Post by fallguy1000 » Tue Nov 14, 2017 8:28 pm
Thanks guys, I made another part today with different glass, 18 oz biaxial. Man does that s..t move and change. I stretched it out and put it on the roller and laid it out and it was like 1 1/2" short! I will just laminate some big arse tapes on it on the join, but another new experience.
33% resin to total is a good number then?
I put another piece of breather on today's part. I will have to subtract for the fabric short, but then I can give another number to see where things are at. I will post another picture of today's work on my build shortly.
Tungsten
Post by Tungsten » Wed Nov 15, 2017 11:39 am
If you use 10lbs of epoxy to wet out 10 lbs of glass thats,50/50 or 50% Vf
same but with 5 lbs of epoxy thats 25/75 . Infusing at max pressure at my elevation (3300') i can get 40 resin/60 glass.
Hand layup i'm around 55% resin.
Post by fallguy1000 » Wed Nov 15, 2017 2:25 pm
Something wrong with my numbers?
Post by fallguy1000 » Wed Nov 15, 2017 3:23 pm
BH3
Total 11.2
Core 3.95
Glass 4.7
Back into resin 2.55
54% resin to fiber.
35/65
Should I back off the pressure?
Post by Jeff » Wed Nov 15, 2017 7:22 pm
Fallguy, I will get back to you around 10:00 AM your time regarding the tape!! Jeff
Tungsten
Post by Tungsten » Thu Nov 16, 2017 5:22 am
BH3
Total 11.2
Core 3.95
Glass 4.7
54% resin to fiber.
35/65
No,as said already if it looks good then don't change it.
If you really want to know what your percentage is do a test on just a small piece of glass no core,weigh before and after.
Post by fallguy1000 » Thu Nov 16, 2017 2:22 pm
Thank you Tungsten.
Evan_Gatehouse
Post by Evan_Gatehouse » Fri Nov 17, 2017 12:59 am
33% by weight for epoxy resin/E-glass is actually a very low % of resin! That is more typical of resin infusions done very well.
I can do a good hand layup at 50/50 but it looks almost dry. 40% resin/60% fiber by weight is more typical of vac bagged layups. Yours might be a little low on resin (but if it all looks wet out... :D )
SK17,MM21/MT24
Post by fallguy1000 » Sat Nov 18, 2017 10:02 pm
These panels look better than anything I have done. My waste is rather high, though. Lotsa epoxy going in the trash in the breather. The wetouts are tough with peelply on the table.
I am using mat backed tapes though and I calculated 10 oz extra weight per sq yd and about 225# add to boat for mat backed tapes. Does that sound right? I can live with it, but not going to tape the tops of my bunks n such unless they get a stress crack later, or might just buy some 12 oz tape for accessible watertights.
I think my vac pump and not opening a bleeder is key to things working.
