Marine epoxy
Re: Marine epoxy
Post by Capt UB » Sun May 20, 2018 9:19 am
Two years ago I was using West System with slow hardener, lots of blush... PITA!!
Started using System 3 with slow hardener and MarinEpoxy with slow hardener, no blush at all!
There were times I wish I had the fast, but things worked out!
Water and NO soap is what I have read with light sanding if after 72 hours (?). Soap could leave a residue....
silentneko
Re: Marine epoxy
Post by silentneko » Sun May 20, 2018 12:19 pm
Blush can appear I'm a bunch of situations. Temperature and humidity play a big roll. I'm in central Florida and the Marine Epoxy with medium hardener would blush a lot if I used it in the evening. Not so much in the day time. Any time blush appears it needs to be removed, no matter how long the cure. The 72 hour thing only really applies to sanding between laminations, but it's subjective because different speeds and resins have different windows from what I've seen. I usually remove blush with alcohol, I don't like water going near my wood.
fishgitr
Re: Marine epoxy
Post by fishgitr » Sun May 20, 2018 9:34 pm
I’m sure it has a lot to do with the humidity then. Since the weather here in Jacksonville hasn’t been great this week. Thanks for all the help guys
