Post by fallguy1000 » Fri Jan 04, 2019 1:26 pm
1708 and the tape are equals; same stuff.
The way they make the tapes is to take a 50" roll and slice or saw it.
The orientation is all that matters; you don't want to purposely turn the fabric 45s because the orientation becomes 0/90
By the way, you can buy 1208 tapes, but it is a special sort of call. I am using some here n there..
Post by Fuzz » Fri Jan 04, 2019 2:09 pm
Cutting tape from your 1708 will work just fine. I like to use a razor knife but any way you can cut it will work.
As for overlaps if you are putting on more than one layer I see no reason to overlap. Just make sure the next layers end in different spots. Say 6 inches or more difference.
Post by Jeff » Fri Jan 04, 2019 3:00 pm
I am learning much from this re-build!!! Jeff
Explorer 19TV
Post by Explorer 19TV » Fri Jan 04, 2019 8:06 pm
Thanks fallguy, the reason I was asking was after much review and discussion I decide to use the following lamination on the stringers,
Two full layers 1708 (completely covering stringer) overlapping the hull 8” then 6”
Next 6” tape
I didn’t want to cut long strips out of the 1708 cloth that came today being stock tape is only 6”. Just a thought gonna lay it out and see what works best as per the 50” width.
Explorer 19TV
Post by Explorer 19TV » Fri Jan 04, 2019 8:10 pm
😁 that makes two of us!!!
Explorer 19TV
Post by Explorer 19TV » Fri Jan 04, 2019 8:12 pm
Thanks Fuzz, that’s what I was thinking kinda the same as offsetting core joints.
Explorer 19TV
Post by Explorer 19TV » Fri Jan 04, 2019 8:55 pm
If I am thinking correctly, one layer of 1708 equals approximately 1/16”.
Post by Fuzz » Fri Jan 04, 2019 10:18 pm
This might come in handy for glass thickness
http://fiberglasssupply.com/Product_Cat ... ators.html
Explorer 19TV
Post by Explorer 19TV » Sat Jan 05, 2019 8:47 am
Thanks fuzz very useful, saves a lot of questions.
Post by fallguy1000 » Sat Jan 05, 2019 9:39 am
Not a full 16th; more like 0.040
