Fairing question
- Very Active Poster
Fairing question
If you have to fair something like a tape ridge, how far away from the ridge do you need to go to fool the eye?
In the picture below, consider a blue tape ridge 1/16th inch proud and the black lines represent the side of the ship running 10 feet in either direction. The top and bottom edges start fair.
How far do you need to go to deal with the tape ridge?
Going 10' seems like too much.
- Evan_Gatehouse
Re: Fairing question
It depends on the curvature of the hull / deck.
On a totally flat surface you'd need to blend the fairing out for a much longer distance.
For moderate curve maybe 6" either side of the tape.
SK17,MM21/MT24
SK17,MM21/MT24
My hulls are very flat. I only have a few of these to deal with..Evan_Gatehouse wrote: ↑Wed Jul 31, 2019 12:32 amIt depends on the curvature of the hull / deck.
I also have some spots where I sanded through triax a tad. Should I neat coat those before I start to fair?
Thanks!
That's similar to taping drywall if you think about it. When I've watched the pros taping and mudding the widest knife I've seen was a 14 inch. Of course those guys start with an 8 and go 2 layers and one pass with the 14 and bam, smooth as if there wasn't a seam at all.
I think Even is right, about 6 inches on either side with the edges feathered.
Didn't you say you had a drywall guy that was going to help with the fairing?
Eric (aka, piperdown)
Yeah. I have a drywall guy coming at some point. But drywall guys are not as good as auto body peeps.piperdown wrote: ↑Wed Jul 31, 2019 8:17 amThat's similar to taping drywall if you think about it. When I've watched the pros taping and mudding the widest knife I've seen was a 14 inch. Of course those guys start with an 8 and go 2 layers and one pass with the 14 and bam, smooth as if there wasn't a seam at all.
6" would show sighting down the hull...
I have a 20"+ trowel and a 30"+ trowel, but there comes a point when a guy can just go too far. A single hump could be faired back the 10 feet.
Maybe I need to get a flourescent light that can go up and down on a stick.
What about precoating my sand through spots?
Thanks. Maybe I need to also build a new base(s) for my Festool for some of the areas longboarding won't fit.
I would neat coat if it were me.fallguy1000 wrote: ↑Wed Jul 31, 2019 8:55 amYeah. I have a drywall guy coming at some point. But drywall guys are not as good as auto body peeps.piperdown wrote: ↑Wed Jul 31, 2019 8:17 amThat's similar to taping drywall if you think about it. When I've watched the pros taping and mudding the widest knife I've seen was a 14 inch. Of course those guys start with an 8 and go 2 layers and one pass with the 14 and bam, smooth as if there wasn't a seam at all.
I've got friends that have restored cars and also know a couple body guys (Dads from scouting). They all layer it on thick and sand it back down then look at it from all angles with bright lights. Even better is a bright day outside (according to them). Easy for them since they just roll it outside. Bit trickier for you since you'd have to have them on dollys. I'd get a couple of big bright lights that can be angled and use them to eyeball the fairing.
- * Bateau Builder *
- Contact:
Light is more essential to the final paint/varnish than to fairing. The key to this is a guide coat of a light dusting of spray paint or graphite powder. This will do a good job of revealing the holidays. Cracker Larry used water but he was working on a covered concrete slab outside; I couldn't justify flooding my shop. The guide coat, in my case, had to be used several times but in the end you can get a decent result, even if you start with this kind of mess:
and paint with a dark color, as I did.
- OrangeQuest
Very nice Tony!! I think I see an ant crawling across the floor carrying a few grains of sugar in the reflection!
I agree and should have included that they eyeball it close after sanding down to match the contours but they use the lights (or sunlight) after the primer is on. And again after painting.
Users browsing this forum: jw01, Netpackrat and 3 guests
