Between Coats of Fairing
Dan_Smullen
Post by Dan_Smullen » Sat Jan 04, 2020 9:02 am
I've been spreading thin layers of blended microballoons and glass spheres, screeding into low areas adjacent to seams, then sanding with a longboard.
Seems to be yielding good results. Haven't got into Quick Fair yet. Have some ordered, and will use for final passes.
I'm wiping down with warm water and letting it dry before spreading the next layer, after sanding.
Should I be wiping down with something harder like alcohol? Should I be rolling neat epoxy before spreading fairing compound?
5965
Re: Between Coats of Fairing
Post by terrulian » Sat Jan 04, 2020 9:49 am
All surfaces should have been saturated with neat epoxy before fairing. Otherwise I don't see the argument for neat epoxy, say between fairing layers, as it is harder to sand.
Jacques likes lacquer thinner for a wipe-down as I think he believes it contains fewer contaminants. I've used water, acetone, and alcohol. I haven't seen much difference, but I'm an idiot.
Post by fallguy1000 » Sat Jan 04, 2020 9:52 am
5965
Decent questions... I like to use alcohol to wipe, but water is okay; just dries slower. Sometimes the alcohol flashes so fast, it is ineffective and water can be better unless you are worried about water deposits..
You can't fair if you roll neat epoxy, so no. However, you really need to make sure to either have key for fairing compounds or be within the recoat windows or both. I don't like fairing over shiny surfaces.
Dan_Smullen
Post by Dan_Smullen » Sat Jan 04, 2020 9:58 am
I’m going to say I have good epoxy coverage prior to fairing. Epoxy was squeegeed over fabric to the point that now cured, I can feel the weave. Then I scuff sanded with 60 grit on an orbital. Then wiped with alcohol.
Bite feels good, and sanding is yielding good results. I was worried about layers biting into previous layers.
Thanks, gents. Keep building!
joe2700
Post by joe2700 » Sat Jan 04, 2020 11:19 am
Why do you say that? I think it only applies to bare wood, maybe that's what you meant. I don't see any reason to have a layer of neat epoxy between saturated cloth and fairing compound. It won't add strength and saturated cloth is already waterproof. I see an argument for neat epoxy over the last coat of fairing compound, as sanding will have opened the top layer of micro balloons/glass spheres. I personally don't, since neat epoxy will mess up my "perfect" faired surface with a hard to sand uneven layer, and I trust the epoxy primer to seal it up. You should do whatever your fairing compound and primer calls for. System 3 yacht primer can be applied directly over system 3 quick fair.
Post by terrulian » Sat Jan 04, 2020 11:25 am
Right, bare wood was what I meant. If you've already glassed a surface, it has been saturated with epoxy.
Dan_Smullen
Post by Dan_Smullen » Sat Jan 04, 2020 11:59 am
10-4.
Users browsing this forum: No registered users and 32 guests
