Deck Replacement, Divinylcell thickness?
Formula Red
Post by Formula Red » Tue Oct 04, 2016 12:15 pm
Planning a composite rebuild on a 15' scooter boat. (Deck, & transom) What thickness of divinylcell for deck replacement ? Laminating shedule? Also, core recommendation and laminating schedule for transom?
Re: Deck Replacement, Divinylcell thickness?
Post by Jeff » Tue Oct 04, 2016 3:36 pm
Formula Red, Give Jacques a little time to respond as he is currently on travel. Jeff
Tungsten
Post by Tungsten » Sat Oct 08, 2016 8:54 am
this will at least give you an idea of what youll need for the deck,
http://multihullblog.com/2010/11/plywoo ... omparison/
Post by Jeff » Sat Oct 08, 2016 10:52 am
Tungsten, thank you for assisting Formula Red. We are all a little behind due to Hurricane Matthew so give Jacques a little more time to give Formula Red some guidance!! Jeff
Formula Red
Post by Formula Red » Sun Oct 09, 2016 10:25 am
No rush.
Post by jacquesmm » Mon Oct 10, 2016 2:46 pm
Tungsten wrote:this will at least give you an idea of what youll need for the deck,
Not applicable to our boats. That is a very weird table, we must be missing something.
Post by jacquesmm » Mon Oct 10, 2016 2:47 pm
Please post repair questions in the repair section. We will move this thread.
Post by jacquesmm » Mon Oct 10, 2016 2:50 pm
Formula Red wrote:Planning a composite rebuild on a 15' scooter boat. (Deck, & transom) What thickness of divinylcell for deck replacement ? Laminating shedule? Also, core recommendation and laminating schedule for transom?
Please see this:
http://forums.bateau2.com/viewtopic.php?f=10&t=13371
What is a scooter boat? A TX scooter?
What is the framing that supports that deck?
I need to know the framing and the type of bond between deck, framing and sheer.
How about the transom? What do you now? Any stringer bonded to the transom?
Formula Red
Post by Formula Red » Mon Oct 10, 2016 11:54 pm
http://gallery.bateau2.com/displayimage ... play_media
Having trouble posting pics. There are 2 pics above linked from formula red gallery.
The scooter boat is a 1990 Majek 15' Scooter. Deck has not been removed yet. I have determined the stringer layout by cutting a few of 3" holes and probing a small rod until I hit the stringers. The current deck is 1/2" ply.
3 Stringers(not top hat), from center stringer to outer stringers is approximately 22" , from outer stringers to edge of boat is approximately 15".
Would like to go with composites. Sugestions for stringer material and spacing if they need replacing, deck material and thickness and lamination schedule. Thank You!
Post by jacquesmm » Tue Oct 11, 2016 10:31 am
Thanks, I can work with that. Give me a couple hours.
