GF16 runners and splash rail question?
piperdown
Post by piperdown » Thu Sep 06, 2018 2:52 pm
Been going through the build threads on the GF16. It's not real clear if builders found long enough wood, scarfed 2 together or laminated plywood for the runners and splash rail.
I plan on glassing over them so which do you all think would be easiest for making the bends?
Eric (aka, piperdown)
Re: GF16 runners and splash rail question?
Post by jacquesmm » Thu Sep 06, 2018 2:57 pm
I have a GF16 and had no problems finding long battens in one piece.
piperdown
Post by piperdown » Thu Sep 06, 2018 3:16 pm
Thank you.
I can find long enough battens, and I don't think the splash rail will be much of an issue bending around the sides. I was more concerned with the bend for the runners.
Post by jacquesmm » Thu Sep 06, 2018 3:23 pm
They all bend very easily.
piperdown
Post by piperdown » Thu Sep 06, 2018 3:29 pm
Thank you!
txjm
Post by txjm » Thu Sep 06, 2018 8:56 pm
They weren’t too bad. I was way more worried about the bottom runners. I made a fixture to keep them the correct distance apart. That also was something I could clamp on. I tapered the ends. I think that also makes it easier to bend.
I used 1x2’s with locators to clamp the spray rails. Rachet straps were also very handy.
Chip
piperdown
Post by piperdown » Thu Sep 06, 2018 9:38 pm
Chip
Thanks Chip. I was wondering about ratchet straps after reading a few other builds. I noticed some would tighten a bit every day until they were in position. Mr. Mertens only calls for 1x1 but I noticed many others using either 1x2 or 2x2 (actual 3/4x1.5 or 1 3/4 x 1 3/4). With the extra thickness I was a bit concerned about cracking the wood.
That's kind of why I was asking in a round about fashion about thin strips or plywood. I can get 1 1/2 x 1/4 clear pine battens 16ft long. I was thinking about laminating 3 of them together as they would make the bend easily individually and form a thick layer with the lamination. Like the rub rail. Then I thought it would probably take a lot of screws (over drilling then filling), so back to the original about being able to bend a thicker solid piece of wood.
txjm
Post by txjm » Thu Sep 06, 2018 9:57 pm
I didn’t use any screws. I did clamp them in place for a couple of days. They seemed to take a set and they were easier to bend. I think I have pics.
txjm
Post by txjm » Thu Sep 06, 2018 10:26 pm
pics
I was actually putting a set in the runners while I was gluing the spray rails on. I did one spray rail at a time and then the runners. the ratchet straps were real tight.
Chip
piperdown
Post by piperdown » Fri Sep 07, 2018 7:53 am
pics
Chip
That helps a lot! Thank You!
