Page 2 of 2
Re: spheretex core material
Posted: Mon Sep 09, 2019 7:47 pm
by fallguy1000
nel.edgar wrote:
Mon Sep 09, 2019 1:57 pm
so.... i searched in the syte of spheretex and they have there a lot of information and also a exemple of use in transoms that u can download... :roll:
as anyone used it as a alternative to wood in transms??
I used corelite 26-28#.
The density of the material is key.
A low density material will crush and mechanically fatigue and drlaminate all but the thickest glass.
Posted: Mon Sep 09, 2019 7:55 pm
by fallguy1000
https://www.spheretex.com/en/product-de ... ansoms.pdf
This is a real pain in the ass way to build a transom.
For my work, I laminated to 20mm pieces of corelite together under lite vac.
Then we built up 4 layers of 1708 on each side, or say about 10mm.
So, we have a 50mm transom.
The spheretex method requires all the intermediate glasswork which is fine, but much more work.
Posted: Tue Sep 10, 2019 12:12 am
by OneWayTraffic
It would be interesting if you could use it to laminate a thin layer over 6mm plywood, to get a 7mm,8mm or 9mm core. Heavier and more expensive than a layer of plywood, but is it any better? They claim better compressive strength than balsa.
I can get some here in NZ to test, but since 6mm plywood is specified in the boats I am considering to build, I do not know of any reason other than my curiosity. Still it's not a lot of money for a 2mm thick 1m square piece, only $10 or so.
I would not consider a transom from it glassed plywood with epoxy plugs around the bolt holes seems cheaper, faster and just better. Maybe for a chopper boat.
Posted: Thu Sep 12, 2019 3:42 pm
by Marshall Moser
Fallguy, can CoreLite be used for hand laminating, or is strictly for vacuum?
Posted: Thu Sep 12, 2019 5:47 pm
by fallguy1000
You can hand glass and hand stack it.
It is easier to stack two 20mm pieces of it using lite vac. You could even bag it with a shop vac, or you can also put weights or bolt pressures. For a professional job, 9-10" mercury and a soft peanut butter mix with a 1/16" trowel both sides gets about a 1 mm thick glue joint which is ideal per my reading at least. You don't need lots of weight. The starting thickness with 1/16th each side is 0.125; so the squeeze is basically filling the voids and forcing some out the edges.
