Yahama Gauges
plumbertuck
Yahama Gauges
Post by plumbertuck » Thu Jun 11, 2009 10:53 am
Can anyone give me some guidance on which gauges I need and how much they cost, I see lots of gauges in my owners manual and I have no idea which way to look. I have limited console space.
I am somewhat interested in fuel /speed / tach.
I have a sending unit in the tank, a simple tempo gauge will suffice for fuel but i think they have some dual purpose gauges.
welcome to the home of the 80 grit rodeo
Old E.
Re: Yahama Gauges
Post by Old E. » Thu Jun 11, 2009 11:10 am
Tach and fuel. Speed is useless. Use a GPS for speed. An hour gauge is nice too, for break in.
Re: Yahama Gauges
Post by Cracker Larry » Thu Jun 11, 2009 11:20 am
I agree, the tach is the most important and an hour meter is good to keep up with engine maintenance. You can get dual purpose tach/hour meter. Speedo is useless but a temp gauge may be beneficial. I also have a volt meter, fuel and trim gauge.
You don't have to buy the pricey Yamaha gauges. Standard teleflex will work fine. Fuel, trim, volts, temp all run about $40 each. Tach about $75. Got all mine from Ebay.
TomW
Re: Yahama Gauges
Post by TomW » Thu Jun 11, 2009 7:46 pm
Tuck, Tach for sure then fuel if you have an interal tank(not neccesary with and external one) then water temp if you suck something up, next volt, since you have a 4st oil pressure would be good. Then hour meter, trim guage. These two are nice but you've been around boats enough to keep a log and feel the trim.
Here is a 4in1 guage for less than $100 that covers all of these. Also look at there site for individual guages the Teleflex guages Larry mentions are as low as $19 http://www.boatersland.com/far-33851.html This is a Faria guage at the top of the line they have others at a lower price in lesser lines. Faria's are better than Teleflex in warranty coverage, but Boatlanders carry a full line of Teleflex. If you can't find what you want they will get it for you.
C17ccx, Mirror Dinghy
plumbertuck
Re: Yahama Gauges
Post by plumbertuck » Thu Jun 11, 2009 10:24 pm
thanks for the tips and the links, I just about choked when the mechanic at my shop that sold me the motor told me the Yamaha multifunction one was $430, or he had a used one for $240, and I needed a "hub" to plug it into, I thought "dang guys I have a plywood fishing boat that I will be bouncing off things with"
Maybe If I had a " Cracker Larry custom machine" :lol:
TomW
Re: Yahama Gauges
Post by TomW » Fri Jun 12, 2009 12:45 am
You'll still need the cable from the motor to the guages. Don't know what that will cost but maybe Larry can get it cheaper.
plumbertuck
Re: Yahama Gauges
Post by plumbertuck » Fri Jun 12, 2009 8:35 am
the cable is there, I have some capped off terminals ( 2 sets) coming from the motor, one set has 3 terminals the other set has 4 terminals, should be all I need.
Tuck
Re: Yahama Gauges
Post by Cracker Larry » Fri Jun 12, 2009 8:48 am
Well, since the motor is obviously running and Tuck probably cranked it with a key switch, I'd deduce that he already has the main wiring harness :wink: The green wire in the main harness is the tack sender for a 2 stroke, but my info says the 4 strokes use the gray wire for the tach. The yellow wire is key-on power, this will connect to the hour meter and anything else you might want key-on power for, such as power to all the gauges.
My engine uses a seperate 4 wire harness for trim gauge, temp and oil level, but everything else comes from the main harness.
Re: Yahama Gauges
Post by Cracker Larry » Fri Jun 12, 2009 8:49 am
Sorry Tuck, you posted as I was typing.
plumbertuck
Re: Yahama Gauges
Post by plumbertuck » Fri Jun 12, 2009 3:17 pm
yup. I need to take a pic of my harness. it will all be clear then.
once again thanks for the help, I will need more later
