LED flood light?
bernd1
LED flood light?
Post by bernd1 » Thu Oct 23, 2014 5:39 am
Hello,
I want to install on the top of my GF16 center console a a LED flood light with a selectable spot beam and wide angle beam. The light should also be removeable from a base to use it as a hand light.
The distance of the beam should be 100m or more.
Could somebody recommend me a light?
On the internet you can thousands......technical data is one side..but the suitabillity the other.
I trust more people which have some experience with it.
BTW....if it is cheap too...it is the right one :D :roll:
Thanks
Bernd
Bowmovement
Re: LED flood light?
Post by Bowmovement » Fri Oct 24, 2014 11:13 am
Heres a link to some LED lights. Not sure if they have what you are looking for but take a look around. Nice LED lights used to be pretty expensive. I was looking at a light bar for my Jeep a few years back that was $1000. It appears they have come down a little.
https://www.superbrightleds.com/cat/marine-lights/
http://marine.rigidindustries.com/
Matt
"Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteers be at the rghit pclae. The rset can be a total mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe."
bernd1
Post by bernd1 » Fri Oct 31, 2014 7:13 am
Thanks
