deck traction
deck traction
Post by OrangeQuest » Wed Aug 15, 2018 10:16 am
Any of you guys that are building flat deck boats and the stand up paddle boat ever consider using any of this stuff?
https://northshoreinc.com/
All our SUPs come with it already and other than a snag or two it holds up pretty good. Thinking of using it on my build.
piperdown
Re: deck traction
Post by piperdown » Wed Aug 15, 2018 12:46 pm
Interesting. Might be easier than me trying to mask off areas for Kiwigrip (I such at painting in general).
Is this stuff closed cell?
Eric (aka, piperdown)
Re: deck traction
Post by narfi » Wed Aug 15, 2018 3:46 pm
honestly..... anything like that should come in Lego pattern..... anything else would be a waste of opportunity!
Re: deck traction
Post by OrangeQuest » Wed Aug 15, 2018 4:52 pm
If it is like the stuff that comes on our SUPs then yes. People are barefoot on our boards but it holds up well. Very firm foam that if your head hits it doesn't hurt so much. I have tested it for that! 8O Water doesn't shed off ours but it also doesn't soak it up.
I am considering using it on the sole and forward casting deck. If it is the same stuff it's easy to cut with a razor knife and maybe a band saw and is easy to glue pieces of different colors together for patterns and such.
We wear surf booties and water shoes a lot so nothing with hard soles on the SUPs. Deck shoes should be ok on the stuff.
Marshall Moser
Re: deck traction
Post by Marshall Moser » Wed Aug 15, 2018 5:26 pm
This reminds me of SeaDek
Re: deck traction
Post by fallguy1000 » Wed Aug 15, 2018 11:00 pm
Faux teak sea deck for me.
Those colors are playground brite. Jist sayin.
Re: deck traction
Post by OrangeQuest » Thu Aug 16, 2018 6:10 am
SeaDek seems to be the same thing and give more details for the DYI guy. Seen a few pictures on the use of the foam around hatches and looks like would be hard to walk on because of the valleys it makes. I like the laser etching option. Gives me something to thing about.
Re: deck traction
Post by fallguy1000 » Fri Aug 17, 2018 9:33 am
I am building up 1/4" foam around the seadeck to keep things flat.
Re: deck traction
Post by OrangeQuest » Fri Aug 17, 2018 6:38 pm
Most all the pictures show they bevel the edges. I am sure so it the edges don't get pulled on but leaves a big gap around hatches.
I am still thinking it would work well on my casting deck!
I could see that stuff would feel great on a big boat like yours that boarding you leave the shoes at the door. And if you have a sundeck on the cabin putting the two layer stuff with a design etched in it.
Re: deck traction
Post by fallguy1000 » Fri Aug 17, 2018 11:08 pm
mine are all going to be inset
preplanning where they go and adding 1/4" core wherever they don't go
all walkways will probably get it
about 250 for 40 x 80 sheet, but was quote $70 sqft for installed flexiteek
