Resin pumps - 1/2 oz?
MarCraft Marc
Post by MarCraft Marc » Wed Jun 05, 2019 3:33 pm
I seem to recall buying these resin pumps for the MarinEpoxy jugs a few years ago and they came with a collar that would reduce the pump amount from 1 oz. to 1/2 oz. That way you could mix a 1.5 oz batch instead of a 3 oz batch (too much for little jobs).
Any thoughts on this? Or how I could maybe rig something similar?
Thanks
Marc B.
FL11, OT16 (sail), PK78, NC 16, Kayaks (4), 21' rowing shell, 14' power skiff, 12' SUP, 3 others, OD18 (in progress)
Re: Resin pumps - 1/2 oz?
Post by narfi » Wed Jun 05, 2019 5:47 pm
It might give some people a heart attack, but I just do 1pump A + 1/2pump B when I need a smaller batch.
Dutch1
Post by Dutch1 » Wed Jun 05, 2019 7:49 pm
Yep, mark half way up on your hardener and don't go past it. There was a thread the other night where they were using mixing spoons to mix real small amounts.
Post by OrangeQuest » Wed Jun 05, 2019 9:59 pm
All my epoxy mixing is done with a digital food scale set on grams. Reference is 100g of resin to 43g of hardener. Increase or decrease as needed. I don't feel comfortable going smaller than dividing by 4, the scale only measures whole grams. The guys advised me a few days ago to use tablespoons and teaspoons for small amounts. I do the expanding foam the same way but it is two equal parts.
The epoxy, I pour the resin, zero out the scale and then pour the hardener in the same cup.
Reid
Post by Reid » Thu Jun 06, 2019 11:44 am
At one point there may have been collars with the pumps. However, the pumps are not metered pumps and if there is any air bubble in the tube when you pump then the ratio can be thrown off. I always encourage all of our customers to use the pumps as a convenient means of transferring resin and hardener to a mixing cup where they can verify the measurements. That being said, MariEpoxy is definitely more forgiving than other systems out there. I simply eyeball my measurements in a cup and have not gone wrong yet.
Think of it this way: What is faster, taking the step of mixing in a measured mixing cup or scraping and sanding uncured epoxy due to a mixing error?
-Reid
- Steven Wright
Reid
Post by Reid » Thu Jun 06, 2019 11:46 am
You can also buy those little medicine cups from Amazon for smaller jobs. https://www.amazon.com/s?k=medicine+cup ... _sb_noss_1
- Steven Wright
Post by OrangeQuest » Thu Jun 06, 2019 12:59 pm
-Reid
Reid is this a trick question? I thought a lot of the guys LOVE the scrapping and sanding part!! :doh:
:lol: :lol: :lol:
Post by OrangeQuest » Thu Jun 06, 2019 1:02 pm
The mariepoxy from BBC also when you mix resin and hardener it clouds up when you start to mix it and then turns clear again as you mix it. I use that to make sure I used resin and hardener and didn't just pour two of the same thing.
Post by TomW1 » Thu Jun 06, 2019 1:07 pm
You can also get bar 2oz cups marked in 1/2 oz.. at Walmart which I have used successfully.
I also hate pumps unless you are pumping into another measuring vessel, as if you do not make the same pump stroke each time you don't get the same amount of resin. You also need to make sure the pump has returned to its full upright position.
Reid
Post by Reid » Thu Jun 06, 2019 1:11 pm
-Reid
:lol: :lol: :lol:
I know, it's my favorite part also!!!
Years ago, when I was pouring bar top resin for a back porch bar I made, I made the mistake of trying to mix a large batch and pouring it all at once. I did not mix it thoroughly and was left with a mess!!! The bar top was approx. 72" x 30" and 1.5" deep. It didn't cure after 4 days in the hot FL weather. It took me a WHILE to get it all off. I learned my lesson, small batches, check measurements, and mix well (this includes scraping the sides and bottom of the mixing container!!!) Came out nice in the end though.
-Reid
- Steven Wright
Users browsing this forum: No registered users and 48 guests
