1708 mat
Re: 1708 mat
Post by jacquesmm » Mon Aug 12, 2019 2:02 pm
BTW, that was not a dumb question at all. I spend a lot of time to think of the workability of a lamination schedule compared to cost and strength.
Re: 1708 mat
Post by fallguy1000 » Mon Aug 12, 2019 10:29 pm
I find 1708 is not as nice on compound turns.
If given a choice, I would prefer to layup the 3 layers of 12 oz. You would have a full day and would not be able to do it in hot sun.
Layout everything dry and put reference lines on the parts to get the overlaps right.
12 oz biax is probably my favorite glass all around; fyi. I would use a good 3/8" paint roller with a good purdy cover or two. Mix then pour into paint trays. Never dump unmixed into the tray. Roll the hull with 40% of the glas weight in epoxy, then roll the glass off cardboard or pvc 3" tubes onto references. This way the glass is already getting wet before you pour on top and consolidate. Each layer is probably an hour of work give or take; so rolling on a wet layer also will prevent the next layer sticking bad if you need some adjustment.
piperdown
Re: 1708 mat
Post by piperdown » Tue Aug 13, 2019 8:30 am
I wish I had known or thought about rolling the glass off of a tube when I was doing my hull bottom. Didn't see a reference to that until 2 weeks after I glassed the bottom. Would have made it easier.
Eric (aka, piperdown)
Tungsten
Re: 1708 mat
Post by Tungsten » Tue Aug 13, 2019 9:37 am
What is the cured thickness of the 1708? Assuming a good hand layup.
Re: 1708 mat
Post by fallguy1000 » Tue Aug 13, 2019 9:47 am
0.040" is what I use.
35 pieces varies from 0.950 to 1.1" when pressed.
Lots of variables.
Tungsten
Re: 1708 mat
Post by Tungsten » Tue Aug 13, 2019 11:57 am
So from my notes 12 0z 45/45 is .022. Hand layup. Say 70 %resin 30 %glass
Tungsten
Re: 1708 mat
Post by Tungsten » Tue Aug 13, 2019 11:59 am
64 pieces?? You vac bagged that many?what.
Re: 1708 mat
Post by fallguy1000 » Tue Aug 13, 2019 1:54 pm
Glass shims. Hand rolled 35 times.
My crew corrected me. Sorry.
1/35 = 0.028 for the pressed version
I still use 0.040 for hand laid 1708 tapes.
nightcrawler
Re: 1708 mat
Post by nightcrawler » Wed Aug 14, 2019 11:33 am
Think i'm going to go 3/12's because it's what i know
nightcrawler
Users browsing this forum: Netpackrat and 1 guest
