Got the Trial kit. What Next...
Bala
Post by Bala » Thu Jan 17, 2008 8:55 am
I purchased the trial kit. What is the best thing to make/build to get a handle on this process?
Thanks,
Regards
Bala
Post by tech_support » Thu Jan 17, 2008 9:09 am
Dont drink it :)
Take two pieces of scrap plywood and make angled joint (say 90 degree to keep it simple). Make a fillet, and glass over it, then fair the joint. Do both sides and you will have made a cross section of one our smaller boats.
Then build a boat :!:
Knottybuoyz
Post by Knottybuoyz » Thu Jan 17, 2008 9:09 am
I used some of the epoxy & glass in mine to fix the fender on a buddy's 4 Wheeler and some of the epoxy to try a resin infusion. You could use some ply scraps to make a joint and fillet and glass that to see how it works.
Yours Aye! Rick
Deedaddy
Post by Deedaddy » Thu Jan 17, 2008 9:12 am
A small center console is something you can use on a lot of the boats.
Bayport_Bob
Post by Bayport_Bob » Thu Jan 17, 2008 9:15 am
If you have enough fiberglass I would:
1. Epoxy a piece of glass to a flat surface.
2. Build a small open box or at least a wood joint from 2 scrap boards (stitching the seams would be another good exercise)
a) Spot weld the seams together with epoxy/wood flour. After the spot weld cures, radius an edge and then go back and fill in one seam with epoxy/woodflour
b) laminate some tape over the seam.
c) Build a fillet on an inside seam with wood flour
d) Laminate some fiberglass over the inside joint & fillet. Preferably working "wet on wet"
3. Fair out the taped seams using the epoxy/blended filler.
4. Spray some rattle can primer over your faired surface so you can see how well the fairing job looks.
Mad Dog
Post by Mad Dog » Thu Jan 17, 2008 1:29 pm
Its a "trial kit", with just enough supplies to do what Shine recommended. That's it!
Russ5924
Post by Russ5924 » Fri Jan 18, 2008 10:02 am
Or do what I did make up a piece of wood set it in the corner and use the trial kit on the boat :oops: 8O :D
D-5 Done and FL12 Done. GF14 80% done
Users browsing this forum: Fuzz and 23 guests
