AR15 Denver
Biney777
Re: AR15 Denver
Post by Biney777 » Thu Mar 07, 2019 2:54 pm
Thanks Bogieman.
The spinnaker chute is being shipped. Now I just have to figure out how it works and what the rigging for it looks like! :help:
Spinnaker chute
Completed Danny Greene "Chameleon" a 10 1/2' nesting/rowing/sailing dinghy. Building an Alexa's Rocket 15 w/ optional retractable spinnaker pole.
Biney777
Re: AR15 Denver
Post by Biney777 » Fri Mar 08, 2019 1:58 am
Not much energy tonight. But I did get one more section of the seat edge glued up. And I used the shrink wrap that was suggested in the tech thread. It looks like it worked well. I will know tomorrow!
Shrink wrapped seat edge lamination part 2
Re: AR15 Denver
Post by Jeff » Fri Mar 08, 2019 8:05 am
Really well done Biney!!! Jeff
Biney777
Re: AR15 Denver
Post by Biney777 » Fri Mar 08, 2019 3:31 pm
Thanks Jeff, I know it is gonna be a push but I would really like to be sailing her by the 4 of July. Yes, this year. :wink:
Re: AR15 Denver
Post by Jeff » Fri Mar 08, 2019 3:45 pm
Just keep working!!!! Jeff
Re: AR15 Denver
Post by Bogieman » Sat Mar 09, 2019 9:53 am
Can't wait to see that once you taken the plastic off. Good work Biney
Biney777
Re: AR15 Denver
Post by Biney777 » Thu Mar 14, 2019 2:58 am
I got the radiused seat edges complete, they came out ok. I found that the stretch wrap was too thin and if epoxy squeezed thru I would have to cut the shrink wrap out. So I tried to put 6 mil plastic down first then stretch wrap the entire piece. The plastic came off much easier but the 6 mil left wrinkles/bulges of epoxy underneath it. I am not sure which way worked better. Probably the shrink wrap and just wipe off the epoxy before you let it set up. The pieces are really straight and seem plenty strong. They get two more layers of glass. 4" Woven tape to cover the gaps and then a layer of woven over the seat tops for wear resistance per the plans.
I still have to install the 2 chain plates and figure out how to rig the retractable spinnaker pole. I have the tube in just haven't found anything that shows how the spi pole rigging works yet. And until I have that figure out I can't put the seat tops on. :help:
Seat edges! They look good! Whew....
Re: AR15 Denver
Post by Jeff » Thu Mar 14, 2019 7:32 am
Nice Biney, good work!! Jeff
Re: AR15 Denver
Post by Bogieman » Thu Mar 14, 2019 8:03 am
Wow! Really nice Biney.
Biney777
Re: AR15 Denver
Post by Biney777 » Thu Mar 14, 2019 1:16 pm
Thanks Jeff!
I have been trying to understand the retractable spinnaker pole rigging. Is/are there any plans with perhaps a more detailed drawing or a build thread that shows how it works? From the pic which I will attach it shows a line going thru an in deck fitting to the aft end of the pole tube, where I assume it attachs to the spinnaker pole end. :?: There are 2 bulkheads between the thru deck fitting and the aft end of tube. :?: Albeit heavily fiberglassed overbuilt bulkeads too btw... :D The best pic I have found that shows how one of these is rigged I will attach as well. It has taken me more than several hours to find this pic but I think I am getting closer to understanding it now! Unfortunately with our "bomb cyclone" all the sailboats in my area are under 7+" of snow right now. Thanks in advance for any tips/suggestions!
The only pic I have found that comes close to matching. I know they are out there, but I have spent several hours looking and needed to goto my actual job.
Best drawing I have found
Pole spec's
Plan drawing
Users browsing this forum: Netpackrat and 0 guests
