AD-14
Re: AD-14
Post by terrulian » Sun Apr 21, 2019 9:58 am
What is the problem flying it on the other side?
bondo
Re: AD-14
Post by bondo » Sun Apr 21, 2019 12:18 pm
The spi pole is on the left side. It is easy to launch on that side (run the tack out to the end of the sprit)
The other side I havent settled out how to run the tack out to the sprit end.
(Maybe I launch from the same side but toss the chute out forward of the forestay?)
Thus far I've flown the sail on the right side by routing the sprit line around the forestay. If this is how to best fly the sail then I will want to use a boat hook to more easily pull the line and around the forestay.
Re: AD-14
Post by Jaysen » Sun Apr 21, 2019 12:38 pm
Then it’s an asymmetrical spinnaker?
What I’ve seen the race boats doing is run the tack around the forestay with the spin still on deck. Clew and sheets run to allow tack across forestay (everyone has a foredeck member run the clew over the stay vs pulling it over with the sheet). When halyard is pulled spin launches lee and you’re off.
Obviously these are multi person teams so it might not work exactly the same for you. I did see one asym split being pulled over a forestay. I assume there was a snag. My captain said “that’s why you run it not pull it” when asked by someone (that may have been me).
bondo
Re: AD-14
Post by bondo » Mon Apr 22, 2019 1:18 am
Thanks Jaysen.
I went again today expecting I would learn more.
But my wife came along and she did all the sailing. (She is a real novice)
She had one long fast tack with the spinnaker on the left side...that was fun.
She was only half able to hide her smile.
bondo
Re: AD-14
Post by bondo » Sat Apr 27, 2019 9:43 pm
The video makes the boat look bow heavy but i dont know...I've shifted ballast out of the bow before only to put it back again. Still, I'm going to adjust trim aft.
I love the spinnaker. Not sure how to sail it yet but it is fun.
bondo
Re: AD-14
Post by bondo » Sun Apr 28, 2019 12:44 am
I don't know if this video gives a sense of speed?
For this boat...this is considered fast under mainsail only.
I can go a little faster but I can't show a little faster.
The camera always gets put away for those conditions.
Re: AD-14
Post by terrulian » Sun Apr 28, 2019 8:57 am
Great stuff. Where are you? Nice breeze and flat water. Boat is looking good! I think when most people visualize sailing, this is what they're thinking of. No terror or thrashing about. We don't get much flat water around here, even on mellow days.
bondo
Re: AD-14
Post by bondo » Sun Apr 28, 2019 10:49 am
The boat is pictured in Lake Washington in Seattle.
By chance these videos show the wind just coming on.
The water is still flat but not for much longer.
I edit the thrashing and terror.
bondo
Re: AD-14
Post by bondo » Tue Apr 30, 2019 9:48 am
AD builders might want to see this video of the spinnaker going up.
(I don't do it well but I probably won't film it again either)
Re: AD-14
Post by gonandkarl » Wed May 01, 2019 3:49 am
Hi,
You did it very well for me it was raised as fast as on a racing sailboat. Did the wind pick up a bit after you took the video ?
