hatch experiments
tech_support
Re: hatch experiments
Post by tech_support » Wed Jan 25, 2012 9:42 am
Thanks Mark. :)
1/ Say, if I sent you AutoCADD drawings/dimensions would you quote on cutting the molds for my hatches? (foam would be cheap to ship too)
We can take a look at it and see if it makes sense. If it cut files can be made fairly simply, then I do not see why not. Send me a sample of what you have in mind.
2/ Do you mind sharing the schedule you used? I saw you mention 2 X 1708... I was planning on 2 X 1708 with 1/2 H80 for most of the middle are to help prevent flex.... is that what yours was in the picture with the H80?
I was going for thickness, about 3/16" single skin around the lip. I used scrap glass for this, but I used mostly 1708 and db1200, db1700 because they can be moved into different directions without puckering. Inside and outside skins are about 1/8" each. The core I used was 2 x 1/2" divinycell, again i used what scrap I had around, it could have been nida core or plywood too.
flyfishingmonk
Post by flyfishingmonk » Sun Feb 05, 2012 2:35 am
This looks like a great thread. Thanks. :)
Do not withhold good from those to whom it is due, when it is in your power to act. PR 3:27
Build Photos at Fly Fishing Monk's Phantom 18
Work Bio at Provision Retirement
Post by fallguy1000 » Sun Mar 29, 2015 10:22 am
Thanks for posting these. I found this thread via google image searches. I looked in the tutorials, but couldn't find much. Again, many thanks. I think I need to build engine covers and some of this might be helpful.
flyfishingmonk
Post by flyfishingmonk » Tue Aug 04, 2015 2:05 pm
Great thread. Now following. Thanks!
Casey
Post by jacquesmm » Tue Aug 04, 2015 2:39 pm
This is a very old thread but yes, there are some good tips in it.
If there are any new questions, I will reply.
Dan_Smullen
Post by Dan_Smullen » Sun Sep 20, 2020 9:07 pm
This thread is gold! Glad I found it.
What is “db1200”?
Post by fallguy1000 » Sun Sep 20, 2020 9:41 pm
What is “db1200”?
12 oz biax
