86 JOHNSON 40 buzzer
Davef
Post by Davef » Tue Jun 06, 2006 2:58 pm
Scott,
I hope you got it fixed. My tell tale is just like Joel's, nice & strong. Did you try clearing the line using compressed air and going backwards?
A decent test for the engine temp is to put your finger on the top of the head and see how long you can hold it there. You should be able to hold your finger there for few seconds (3-5 +/-). A shorter time and it's hot, longer & too cool.
Good luck
L8tr
d
FLYonWALL9
Post by FLYonWALL9 » Tue Jun 06, 2006 3:26 pm
Thanks Brothah Dave :!: ... After pulling the foot off several
times thinking I put the pump on wrong, checking the supply
tube yadda yadda. Then I pulled the t-stat housing a few time
bottom line is it was all apart no less than 8 times i'm a pro
at it now. it runs great. now i just gotta get the idle, wot
on the carbs set correctly. :doh: ....
How bout an update on your new family members, havne't
heard an update in a few months.
Davef
Post by Davef » Wed Jun 07, 2006 9:22 am
I would recommend a factory manual if you don't have one. I couldn't live without mine. It will guide you through the link & sync without a problem.
Leah is doing great. She's 2 now so I'm sure you know what that means. Can't wait until she's 3. :lol: We are still in the process for our second. It's taking a lot longer now than before. We have at least another year. Thanks for asking.
L8tr
d
